-   -   Need Help with Transition Between Rooms (http://www.diychatroom.com/f15/need-help-transition-between-rooms-70424/)
vtmike24 05-03-2010 07:56 AM
My wife and I are remodeling the house we just bought before we move in. We would like to paint our adjoined living room and dining room different colors, but the current construction makes the transition between rooms difficult.
The wall between the rooms has HVAC above it and columns in between, which I believe are structural. We are trying to fix this problem area without spending a lot of time and money. I was thinking of adding trim around the entryway. With a normal sized wall you would frame it out and paint and the trim the same color, however that was is pretty wide and I don't think that would work out well.
We are going to remove the carpet and add hardwood floors in addition to adding crown molding.
Looking for ideas, please help!
http://www.hondashowoff.com/forums/p...&pictureid=203
bjbatlanta 05-07-2010 09:03 AM
I think going with trim is the easiest solution. Rip some birch plywood for the wide surfaces and use casing around it. Paint to match the trim.
