Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-13-2009, 11:45 PM   #1
need help removing beadboard
Hi, I'm new to this site and was wondering if anyone could tell me the best way to remove glued on beadboard that is on sides of wood cabinets...I want to reface the cabinets and need to remove the beadboard as it was installed incorrectly to begin with. Thanks for any suggestions you might have!!!!! Oh, BTW the beadboard is made is not made out of wood, but most likely partical board.
chipster is offline   Reply With Quote
Old 03-14-2009, 07:27 AM   #2
Getting it off without damaging the cabinet can be a challenge. If there is a loose edge, start there with a long wide putty knife, and sometimes a heat gun helps(low setting). Slowly work it with the heat and knife. Good luck.
Beadboard Backsplash nthomp16 Building & Construction 12 02-06-2011 04:28 PM
Beadboard chair rail over uneven walls pmoe Carpentry 8 02-21-2009 10:27 AM
prep walls after removing paper ponch37300 Painting 1 01-10-2009 11:54 AM
Removing Gas valve/pilot control Fuzzybunny HVAC 22 12-14-2008 08:24 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
