Need Help With Large Door Casing Fix - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 09:30 PM   #1
I have the same problem but with an exterior door being too close to a joining wall on the interior. to door is so close to the wall their is apsolutly no room for any kind of trim or casing. I can't move to door nor to wall. What would be the best solution? the drywall on the interior wall is flush with the rough opening of the door jam. The jam is 3/4 inch thick so that's all I have to play with.
Jumbo is offline   Reply With Quote
Old 01-08-2012, 09:34 PM   #2
Rewards Points: 13,712
Jumbo, go back and start you own post, that way you will get your ansewers and there not confused with the other posters replys.
Also attach a icture of what you have or everyones going to have to just guess.
Old 01-08-2012, 10:16 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 390
Joe is right that you will get more answers if you start your own thread but getting confused with the OPs info it shouldn't make any difference since that is a 2010 thread.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-13-2012, 10:26 AM   #4
Maybe trimming the door and adding a stud to the opening is an option
norkota is offline   Reply With Quote
Need ideas for large, multi-space living room D-Lew Interior Decorating 2 01-03-2012 12:26 PM
redecorating a large wide 1950's bungalow hallway HOLLYROSE Interior Decorating 1 12-01-2009 12:14 AM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 04:34 PM
large mystery plywood panel in garage - any thoughts on this?! joeyboy General DIY Discussions 15 12-02-2007 03:01 PM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 05:28 PM
