-   -   Need dryer vent material and installation suggestions (Mobile Home) (http://www.diychatroom.com/f15/need-dryer-vent-material-installation-suggestions-mobile-home-159207/)
no_Wedge 10-06-2012 09:04 PM
I have a mobile home and need to vent the dryer out. I have a hole already and 2 90's going to the top of the hole, then I have to duct it through the underbelly(the problem is there is an air duct somewhat under the hole and it has to be angled)
then i have to run another 90 or 45 coming out so it can vent to the rear ~8-9 feet out.
What would be the best way to do this? solid pipe going through the underbelly, or can i run a foil type flex to the underside, also what material to vent the 9 feet distance?
Daniel Holzman 10-06-2012 09:08 PM
Best material for dryer vent is galvanized steel duct or aluminum duct. Do not river or screw the pipe together, as the screws or rivets tend to collect lint inside. Use foil tape to connect the pieces.
techpappy 10-06-2012 09:59 PM
agreed ..steel or aluminum pipe with silver heating duct tape at joints...because so many elbows see if you can get a 4 inch to 5 inch elbow so you can increase duct size under trailer...would increase air flow for proper operation of dryer..most dryers allow nominal 15 feet venting..each 90 elbow adds five feet..judge accordingly..also install back draft damper on end
no_Wedge 10-09-2012 08:27 PM
ok have all the pipe in, used the galv. steel 4in. I was needing to know though if I need to wrap foil tape around the Adjustable 90's seams?
also the duct is kind of touching my insulated air duct that connects the air vents on the two sections of the house. Will the heat from the dryer duct possibly melt the insulation around the other air duct?
Missouri Bound 10-09-2012 08:39 PM
No tape needed on the adjustable elbows. And it wold be best to keep the duct away from the hvac duct. Is that possible? When a dryer is working "properly" it won't get the duct hot enough to melt the protective wrap on an insulated hvac duct. But there are a lot of dryers which can run very hot and created an issue. This is usually due to a blockage of sorts. Personally I know this because I had removed a load of laundry from a dryer and had to drop it in about 3 steps due to the heat of the load which was burning my arms. The dryer had a defective thermostat.
no_Wedge 10-09-2012 09:01 PM
well i can get it were it's not touching but it will still be close to it.
