Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-04-2006, 09:57 AM   #1
Question
Need a Covering for a Concrete Carport
I have been trying to improve our outside carport. I cleaned the cement, used Hydrogen Peroxide to remove an oil stain, I have painted the wood, but I would like the cement to look nicer. It's about 40 year old cement, so it has some permanent wear on it. Is there a type of paint or covering that I can put over the cement to make it look like new - - or at least better? :confused:
Amanda is offline   Reply With Quote
Old 04-09-2006, 12:00 PM   #2
Darylh's Avatar
Use a High grade Exterior Epoxy Concrete foor paint. Make sure you have a good clean floor. I use Tsp and rince it very well. After the paint had cured for a couple days at least, put down some Runners where the tires touch the concrete. Nothing peels paint off a floor faster than Hot Tires. They also have clear concrete floor finishes two. Your local Paint store should have everthing you need.
Darylh is offline   Reply With Quote
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
Need a Covering for Concrete Carport Amanda General Discussion 2 05-10-2006 01:26 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
