Need Advise With Insulated Foam Sheathing - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-19-2010, 03:14 AM   #1
Need advise with insulated foam sheathing
So I want to install vinyl siding over this nasty,40 something year old asbstos siding I have on my house.
I want to hang insulated foam sheathing unders the vinyl.
The pink type you get at Home Depot:
I was thinking I would first attach home wrap, then 1/2" foam sheathing followed by vinyl siding.
I'm looking for some advise on whether this is a good/bad idea.
If this is a good idea perhaps some useful advise/pointers on instalation.
rworld2 is offline   Reply With Quote
Old 01-21-2010, 01:52 PM   #2
I would think 1/2 is somewhat pricey. I put vinyl siding over my old asbstos shingle home back in 2002. I nailed up what they called "fan fold" just to help create a somewhat even surface for the vinyl. I wasn't looking for any insulation value.
ferris13 is offline   Reply With Quote
Old 01-21-2010, 04:36 PM   #3
Rewards Points: 562
"I" would take off the siding first. Check locally and see what where and how to do it yourself safely. VERY few fibers coming of this stuff and down the road,,better now than later. When you hit it with a nail it shatters like glass,,,combine gravity,build up at the bottom,,,whats it going to look like??
4just1don is offline   Reply With Quote
Old 01-21-2010, 05:56 PM   #4
very little cracking..and if one did crack the fan fold held it in place. They didn't slide to the bottom. I believe if you ever sell you would need to disclose that the siding does exist. Call up the local building dept.they will advise.
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Rigid foam sheathing on top of foam insulation? benjamincall HVAC 12 02-04-2009 12:41 AM
Exterior Foam sheathing thickness? teachtech Building & Construction 4 11-29-2008 04:36 AM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 04:42 PM
Best Ext. Sheathing: Rigid Foam An Option? austinbirdman Building & Construction 3 12-15-2006 09:02 AM
