Need Advice Sizing Bathroom Fan - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-10-2014, 12:31 PM   #16
Condensation isn't a leak, so sealing won't help. It's the same as when you place a glass of ice water outside on a warm day. The water in the air phase changes due to the temperature and becomes a liquid. Insulation keeps this from happening.
trevarthan is offline   Reply With Quote
Old 02-10-2014, 02:35 PM   #17
Rewards Points: 165
You can buy the insulated flexible ducting thst joecaption linked to and remove the insulation from it. Then take the insulation and slip it over the rigid ducting.This is a bit more expensive an option due to the wasted materials, but this is what I have done with my rigid exhaust ducting in my attic.
chronojosh is online now   Reply With Quote
Old 02-10-2014, 02:43 PM   #18
I've been curious about this for a while... is duct insulation available at the big box stores, or does one have to special order it, or scavenge as the previous post mentions?
Old 02-10-2014, 02:54 PM   #19
Rewards Points: 398
I found this but it looks like 3" is the max they sell - I didn't see 4".
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 02-26-2014, 02:13 PM   #20
I installed the panasonic whispergreen 130 cfm fan this weekend using two 90 degree 6" elbows, a 6" to 4" reducer, and a short run of vinyl 4" duct in a corkscrew. Yeah, I know, it's a terrible configuration.
Surprisingly, this performs a little better than my previous fan install. But just barely. At the roof, with the fan dialed all the way up to 110 CFM, it opens the vent flap about an inch. The old fan wasn't even able to open the vent flap, so that's good.
However, I've decided it would be a waste to continue running this expensive fan at severely reduced efficiency, so I'll be installing a new 6" roof vent further up the roof. This will allow me to use just one 90 degree elbow and 6" pipe the whole length. Should solve the problem permanently.
Old 02-26-2014, 02:58 PM   #21
An old Tradesmen
Rewards Points: 6,510
Yeah, you'll get much better results that way.
Bathroom tile advice needed. John_W Flooring 13 02-08-2013 02:57 PM
Wiring Basement Bathroom Advice natspawpaw Electrical 6 01-13-2013 09:45 AM
Want to avoid full demo on Small Bathroom - Need Advice BayIslandMike Remodeling 5 12-27-2011 11:49 AM
Installing Bathroom in Basement Need Advice Jeffrey262 Plumbing 6 05-12-2009 07:33 AM
Any advice for new bathroom plumbing?? melissamarie9 Plumbing 3 04-16-2009 09:46 AM
