Need Advice On Putting Cedar T&G Planks On Ceiling In Bathroom - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 11:17 AM   #1
Need advice on putting cedar T&G planks on ceiling in bathroom
I'm redoing the bathroom and need some advice on how to properly put up Western Red cedar planks on the ceiling. Above the ceiling is the attic (only insulation, no floorboards). I live in Northern Virginia (Climate Zone 4, mixed humid).
This is what I've gleaned so far from research:
1) Varnish all sides except living area side of cedar planks
2) Nail 1/8" to 1/2" battens to joists (16" o.c.)
3) Affix cedar to battens using flooring method (nail 45 degree into tongue)
4) Use some sort of oil (Danish oil seems to be recommended by the Western Red Cedar Lumber Association) to finish facing side of cedar, and keep it looking colorful
Does this sound correct? How effectively would any moisture that gets past the cedar vent through 20" of insulation? Could I just install 1/2" plywood boards on ceiling, drill x number of 1/2" holes for venting and save myself the hassle of battens?
Thanks in advance!
pazure is offline   Reply With Quote
Old 03-09-2012, 02:07 PM   #2
Weekend Builder
Crackers's Avatar
I would put a fan to exhaust moisture; which is bad in any climate.
Vapor barrier on warm side of the insulation (read: between insulation and the cedar) will prevent condensation / water problems / air leak.
Crackers is offline   Reply With Quote
Tags
bathroom ceiling moisture , cedar , renovation
How to fix a peeling bathroom ceiling lmaxson Painting 16 02-20-2012 02:55 PM
advice on bathroom window and makeover for bathroom charles101 Windows and Doors 11 04-10-2011 09:37 AM
bathroom ceiling mildew/mold problems ditchdoc7893 General DIY Discussions 3 03-19-2011 07:24 AM
Advice Installing Support in Ceiling for Hanging Ceiling Pot Rack hovenj Building & Construction 7 01-02-2011 12:31 PM
Best primer for bathroom ceiling dbldee20 Painting 11 01-06-2009 04:25 PM
