Need Advice In Joining 2 Beams - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-27-2009, 08:02 AM   #1
Need advice in joining 2 beams
I'm building a pergola over my existing deck. It measures 12 x 17. The longest beams I can find at HD are 16' therefore I'll have to join 2 beams in the middle post. What would be the best way to join them?
ray1031 is offline   Reply With Quote
Old 05-27-2009, 08:27 AM   #2
Not so new
12penny's Avatar
Rewards Points: 520
ray...or you could go to a real lumber yard and buy 20' lumber. Then you may not need a center post at all.
12penny is offline   Reply With Quote
Old 05-27-2009, 09:14 AM   #3
Old School
cabinetman's Avatar
WELCOME TO THE FORUM
You could use a half lap joint like this, or a mortise and tenon, using a waterproof glue, like TBIII.
cabinetman is offline   Reply With Quote
Old 05-27-2009, 09:29 AM   #4
waterman1971's Avatar
Rewards Points: 154
What size beam are you planning on using? Perhaps double up with smaller sized lumber and acheive the same span at little additional cost.
waterman1971 is offline   Reply With Quote
Old 05-27-2009, 09:34 AM   #5
Newbie Bill
Rewards Points: 522
12 penny hit the nail on the head so to speak.
Check around.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 05-27-2009, 04:45 PM   #6
Thanks for all the replies.
I already have 3 posts in each side so I'll use one of the recommended joints mnetioned earlier by getting 6 12' beams.
Any ideas about creating a template for the ends?
Old 06-09-2009, 10:49 AM   #7
Attaching rafters to the beams.
My beams are up and ready for the rafters. I've read many things about pergolas but I still have some questions and any feedback would be greatly appreciated.
1. How much space should each rafter have from each other, I've heard 12" and 24"?
2. Should the rafters be toe nailed to the beams or should I use metal braces for stronger support?
Old 06-09-2009, 12:10 PM   #8
Mold!! Let's kill it!
Rewards Points: 2,012
What are you building the rafters from? If it's PT, then they will undoubtedly twist and warp all over the place unless you tie them together. I've seen them on all centers from 12" to 16" to 24". it's all in the look you want. Toe nailing should be fine. The only load they will bear is their own weight.
Old 06-10-2009, 09:22 AM   #9
Yes it PT and I'm affraid about that.
Faux Wood Beams JudyFaye Building & Construction 2 06-08-2012 04:05 PM
Joining 2 beams in a 17ft span pergola ray1031 Flooring 2 05-27-2009 07:59 AM
Beam Building - Structual Advice projects @ home Building & Construction 2 05-03-2009 08:33 AM
hanging weight off of tji beams?? summer76 Building & Construction 2 04-14-2009 02:00 AM
Adding supports for beams and joists pinkertonpv General DIY Discussions 2 08-13-2008 02:04 PM
