Is It Necessary To Level A Concrete Floor With A Slope Of 1" / 13.5 Feet ? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 10:04 AM   #1
Is it necessary to level a concrete floor with a slope of 1" / 13.5 feet ?
our garage/basement floor has a really good finish,no dips or bumps and is sloped 1 inch every 13.5 feet. the basement/garage is 54 ft by 26 feet. The slope is 4 inches over the 54 ft length of the home. I am finishing the basement/garage into an in-law apartment the first 34 by 26 feet. Is it necessary to level the floor with such a minimal slope? No room will have more than a 1 inch slope over a 13 ft width. We will be using Laminate flooring and carpeting in various rooms.
johnnewengland is offline   Reply With Quote
Old 03-19-2012, 10:14 AM   #2
Rewards Points: 13,450
Not worth the extra time for little a slope.
How dry is this basement?
Both laminite and carpet can be a real problum with even a damp basement.
Most laiminites are not even rated for below grade installs, read the box or go on line and check it out before buying.
Engineered flooring may be a better choise?
Has anyone done a moisture test yet on this floor?
Old 03-19-2012, 10:30 AM   #3
No moisture test yet. the home is high and dry but we will test it. We will buy laminate for below grade install, use a moisture barrier etc.
Old 03-19-2012, 03:17 PM   #4
I am in process of finishing a basement which is built into a steep hill. It had water issues in remote past and french drains put in by previous owner so I was concerned about the possibility of problems with dampness and flooring. I talked to 3-4 flooring places about what to use and they were very consistent is recommending a laminate floating floor.
canoes is offline   Reply With Quote
Old 03-19-2012, 04:42 PM   #5
laminate flooring
Thanks for the info canoes. We got the same recommendation on laminate. As far as carpeting, they say to put down a moisture barrier that is also a pad. Lowes has it.
How to level small patch of cured concrete? RDS General DIY Discussions 11 06-05-2008 12:41 PM
pouring a level concrete slab over sloped concrete Jayne Building & Construction 4 05-11-2008 08:55 AM
HELP! Concrete Pad NOT level happy 51 Building & Construction 4 06-20-2007 09:07 AM
Level finished concrete generaldorf Building & Construction 5 01-15-2007 02:38 PM
Tile on concrete slab, ground level - bamboo? IvoryRing Flooring 2 06-28-2006 08:52 AM
