-   -   Is it necessary to level a concrete floor with a slope of 1" / 13.5 feet ? (http://www.diychatroom.com/f15/necessary-level-concrete-floor-slope-1-quot-13-5-feet-137508/)
johnnewengland 03-19-2012 10:04 AM
our garage/basement floor has a really good finish,no dips or bumps and is sloped 1 inch every 13.5 feet. the basement/garage is 54 ft by 26 feet. The slope is 4 inches over the 54 ft length of the home. I am finishing the basement/garage into an in-law apartment the first 34 by 26 feet. Is it necessary to level the floor with such a minimal slope? No room will have more than a 1 inch slope over a 13 ft width. We will be using Laminate flooring and carpeting in various rooms.
joecaption 03-19-2012 10:14 AM
Not worth the extra time for little a slope.
How dry is this basement?
Both laminite and carpet can be a real problum with even a damp basement.
Most laiminites are not even rated for below grade installs, read the box or go on line and check it out before buying.
Engineered flooring may be a better choise?
Has anyone done a moisture test yet on this floor?
johnnewengland 03-19-2012 10:30 AM
No moisture test yet. the home is high and dry but we will test it. We will buy laminate for below grade install, use a moisture barrier etc.
canoes 03-19-2012 03:17 PM
I am in process of finishing a basement which is built into a steep hill. It had water issues in remote past and french drains put in by previous owner so I was concerned about the possibility of problems with dampness and flooring. I talked to 3-4 flooring places about what to use and they were very consistent is recommending a laminate floating floor.
johnnewengland 03-19-2012 04:42 PM
laminate flooring
Thanks for the info canoes. We got the same recommendation on laminate. As far as carpeting, they say to put down a moisture barrier that is also a pad. Lowes has it.
