My Basement Project - Framing - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-16-2012, 10:59 PM   #16
Thanks for your response. Do you have any photos showing what you just explained? not sure if I got the picture. also you mentioned using fire blocking foam on the back of top plate?
Originally Posted by hand drive View Post
double stud on the outside corner. for a taller wall, at about the center of the wall add blocking in the stud bays that tie the outside corner to the rest of the wall.
a good and strong inside corner consists of.. on one wall put two ganged up studs in with 3 or 4 2x blocks spacing the 2 studs to 4 1/2" ( imagine 3 studs nailed together but the blocks take the place of the middle stud) .
on the other wall add one stud that nails to the ganged up studs. there will be 1 1/2" for drywall to nail to coming out of the corner of the wall and the other side will have 1" to nail drywall to.
you can also pre build the inside corner first and then put it into the wall...
kimbhoot is offline   Reply With Quote
Old 09-16-2012, 11:14 PM   #17
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
In reference to the issue with moving the top plate for level after being nailed.
You could have use a "cats claw" to remove the nails with minimal damage to the plate.
sublime2 is offline   Reply With Quote
Old 09-16-2012, 11:20 PM   #18
Rewards Points: 2,212
For inside corners make an L out of 2 studs, the other wall just has an end stud.
or have a 2nd from last stud 4" from the corner.
Here are lots of examples of different styles https://www.google.ca/search?q=wall+...w=1439&bih=740
mae-ling is offline   Reply With Quote
Old 09-16-2012, 11:21 PM   #19
http://studio-tm.com/constructionblo...crete-slab.jpg
this is what I'm referring to as an inside corner. in this case, the right bottom plate extends out. in my case, the left top and bottom plate extends out to right wall line.
http://www.basements101.com/framing2.html
I'll be using this method for the inside corner. Now the question is, my 16" on center would start where in reference to the corner?
http://www.build-home-building-house...ges/wall09.gif
I'm going to use the first method for my wall. Do I use standard 16" oc for the left frame?
Old 09-17-2012, 12:05 AM   #20
As you are not putting sheeting on the outside your spacing can start from the inside corner.
First method is good, yes use standard 16"OC spacing
Old 09-17-2012, 07:30 AM   #21
AHH, SPANS!!!
Rewards Points: 1,166
you do not want dead air space behind the wall where it meets floors and such. the top plate of the wall seals the top of the wall from the floor joist bays above so you want to seal behind the wall against the top plate so the air space in the wall does not travel up into the joist bays above.
sorry, do not have a pic for the corner detail. My explanation for the outside corner was actually for the end of the wall, oops- but a double stud that is nailed together on the outside corner works great and is a strong corner.
for the inside corner, imagine three studs (triple) nailed together and placed in the wall, the thickness of the wall is 3 1/2" and the triple is 4 1/2" .
found this on google, the fist diagram on the first page is exactly what I'm mentioning and see how they added blocks in the corner to save from using extra studs ...
http://extremehowto.com/a-smart-way-to-frame-a-corner/
hand drive is offline   Reply With Quote
Old 09-17-2012, 10:32 PM   #22
Around here that is considered the worst way, much less insulation then a L corner.
Old 09-23-2012, 11:01 PM   #23
Vapor barrier
Need some advise on vapor barrier. I was advised by the Home Depot project manager that I install the polyethylene on the back of the framing and lift the frame up using plastic shims under the treated floor plate. he said that will allow the vapor (if any) to cycle in and dry. On my first wall, I wasn't able to put plastic shims under as my walls were pretty tight. should I remote the plastic from the back and put them on the front side? I won't be using any insulation.
please advise on how to correct this wall and proper way on any other walls I'll be building.
Thanks.
Old 09-26-2012, 08:52 AM   #24
I know it's an extra expense, but I would HIGHLY suggest putting insulation in. My brother finished his basement about an hour and a half north or KC and didn't put any in. That place was fairly cold during weather like we have now. I can only imagine what it would have been like during 0 degree weather if he wouldn't have sold it. If I was finishing a basement, it is something I would definitely put in.
ws450r is offline   Reply With Quote
The Following User Says Thank You to ws450r For This Useful Post:
kimbhoot (09-26-2012)
Old 09-26-2012, 09:56 AM   #25
this last winter wasn't a very cold one but I spent quite a bit of time in the basement without any heating and it didn't feel much cold there. I would definitely consider that once the framing is complete but I'm really trying to address the moisture issue before the framing goes up.
any advise?
Old 09-27-2012, 12:59 AM   #26
Registered User
Rewards Points: 5,514
No plastic; http://www.buildingscience.com/docum...lation-systems
http://www.buildingscience.com/docum...ts?full_view=1
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
kimbhoot (09-27-2012)
Old 09-27-2012, 10:22 AM   #27
GBR in WA,
I see the issues listed on the links. So do I just leave it bare and build my frame and put drywall in? as I mentioned, I'm not putting any insulation. or do you recommend putting insulation between the studs? I've already put one wall up with plastic behind it. what can I do about that?
Thanks again.
Old 09-27-2012, 06:25 PM   #28
Rewards Points: 16
I think that you should put some insulation in. It's not that much money.
I recently finished my basement and put foam sheets on the concrete wall then framed a 2x4 wall and put insulation in the stud bays.
I'm glad I did, it's already warmer and quieter.
Good luck.
chongololo is offline   Reply With Quote
Old 09-28-2012, 11:49 AM   #29
Read those links again, the styrofaom against the wall is key!
The Following User Says Thank You to mae-ling For This Useful Post:
Gary in WA (09-28-2012)
Old 09-28-2012, 10:23 PM   #30
Registered User
The foam board air seals the concrete against summertime condensation, especially above grade. Plastic alone will stop moisture through the concrete but not room air from condensing on it, need foam board.
Read the last link in post #11, for the best way to stop moisture.
Gary
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Another basement framing thread fbaggins Remodeling 3 07-07-2010 11:48 PM
Basement Framing vapor barrier emccarthy2 Building & Construction 2 03-24-2010 06:35 AM
My Basement Project sail3695 Building & Construction 4 01-05-2009 08:03 PM
Framing in a walk-out basement ryanc Building & Construction 2 01-19-2008 10:54 AM
