Musty Smell In Crawlspace - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-01-2010, 08:24 PM   #1
musty smell in crawlspace
how do I get rid of musty smell coming from crawlspace? seems about 90% dry just a little damp in corners other than that pretty dry! limestone 57's covering everything!
cinders is offline   Reply With Quote
Old 10-02-2010, 08:46 AM   #2
Make sure you remediate your moisture/humidity problem first (gutters, downspout placement, proper grading, trench/french drain if necessary, sealing crawl space, sump pump, etc.) or your efforts will only be temporary. With that said, I used a 50/50 mixture of white vinegar/water in a pump sprayer first, then a couple of days later a mixture of baking soda & water from the same sprayer. That was 2 years ago after I installed my vapor barrier, and sealed up my crawl space, and it still smells fresh and clean today.
littlecleo is offline   Reply With Quote
Old 10-02-2010, 09:56 PM   #3
Rewards Points: 5,332
You should put a humidistat in the area to see what the humidity level is. Does the crawlspace have vents?
What is limestone 57?
Ron
Musty crawlspace smell coming into house tmpyankee HVAC 6 08-20-2015 09:46 PM
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Armstrong Grand Illusions musty smell works2much Flooring 8 12-21-2011 07:56 PM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 08:36 PM
musty crawlspace svmaine Building & Construction 2 09-03-2007 03:53 PM
