Musty Basement Floor - Grind Concrete? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 08:50 PM   #1
Q14
A couple days ago we had asbestos tiles professionally removed from the basement, but the layer of mastic was left behind. After they were gone our basement smelled horribly musty, which it didn't when the tiles were there. I'm not worried about mold, but I want the smell out asap before it takes over the rest of the house. Would a concrete grinder do the job best/fastest? And then seal it with a concrete sealer. (We have been ventilating using airflow, fans and a dehumidifier. Also used TSP and bleach treatment which helped bring the smell down but it's still strong) Any thoughts? Thank you so much for your help!
Q14 is offline   Reply With Quote
Tags
floor , grinder , musty basement , tiles
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Older basement shower needs remodel. Questions about showers and concrete blocks. speedster1 Remodeling 6 01-28-2010 02:55 PM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 06:13 AM
