Mullion Doors For Kitchen Cabinets? - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By TheCabinetShop
Old 08-27-2013, 01:39 PM   #1
DIY-Her's Avatar
Rewards Points: 217
Mullion Doors for Kitchen cabinets?
I'm thinking to place mullion glass doors on 2 of my double door 42" kitchen wall cabinets. My question is, the shelving in both these doors are not the same heights. I adjusted them according to what dishes and glasses we place on those shelves.
Do mullion doors have to match the shelving height? Trying to figure out if we should go with
2x2 (4 lites),
http://www.rawdoors.net/doorpreview....=&h5=&hd=Right
2x3(6 lites)
2x4(8lights)
or, should I go with the vertical only?
DIY-Her is offline   Reply With Quote
Old 08-27-2013, 01:50 PM   #2
K&B Designer
Live_Oak's Avatar
We'd need to see pics of your kitchen to see if muntin doors would suit your style of cabinetry. And in turn, the style of the house also comes into play. Muntins are a very traditional look, and for instance, if the home lacks traditional details, they may not work as well as would a single pane of glass.
Live_Oak is offline   Reply With Quote
Old 08-27-2013, 02:15 PM   #3
DIY-Her's Avatar
Rewards Points: 217
it's a traditional house and decor.
This is the cabinets before I painted the upper wall cabinets and finished painting the wall. I don't have new pics yet.
Here is a picture of the one set of cabinets on the left of the sink that I want to do the mullion doors. I will also be doing the same on the right side.
We are also going with the euro hidden hinges on the 2 cabinets and gradually buying the same for all the others.
I'm also in the process of deciding what to do with the bottom cabinets, I want to refinish them as I've done in my previous house, but don't know the stain color yet.
Will eventually be getting a Silestone, Caesarstone or Cambria countertop and hopefully a walnut butcherblock top for the center island. that is why I'm holding off on deciding the stain color for the lowers.
Old 08-27-2013, 02:46 PM   #4
K&B Designer
Live_Oak's Avatar
With the cathedral style doors and height of those doors, of your choices, 2x3 would probably look the best. I would also think about no muntins and an obscure glass so the interiors wouldn't have to be constantly policed for visual appeal. Also, with no room crown, and the white tile floor, the home's bones read more as transitional than traditional, and the single pane would be appropriate to a transitional style
You did a nice smooth paint job over that old oak! Did you paint the interiors as well? Have you also thought about beefing up the crown molding? Paint will hide all of the differences, and since you said "traditional", nothing says traditional like a more beefy crown.
Old 08-27-2013, 03:03 PM   #5
DIY-Her's Avatar
Rewards Points: 217
no, I didn't paint the interior cabinets, but I did of course take off the doors and did the back of the doors. I've looked at many white cabinets in stores and found many aren't painted white inside, but a light color finished wood.
I also put at least 5 coats on, 1 of Zinsser 123 primer and 2 of satin since I bought that originally then decided I liked the semi gloss better. I waited for the last coat to use the semi gloss and sanded 400grit between each coat.
Actually I have nice plates that we have had hidden in the bottom of our dining room hutch for years and I want to bring them out and display them in those cabinets along with our every day dishes on the 1st lower shelf. The outside of the house is brick federal style with glass circle top window on all the first floor windows on the front of the house.
Here is the other side of the kitchen with the table and new light
and the new light over the sink
and the foyer that directly leads to the kitchen.
Old 08-27-2013, 03:08 PM   #6
DIY-Her's Avatar
Rewards Points: 217
oh, we eventually want to put 12" upper cabinets on top of the 42" and light the insides with maybe one display item in each.
Also, depending on the color stain I go with the island, I want to choose walnut or other wood for a butcher block top similar to this
Old 08-27-2013, 04:09 PM   #7
DIY-Her's Avatar
Rewards Points: 217
forgot to mention the foyer (18ft), living and dining room (9ft), all off of the kitchen have wide crown molding with about 4 inch molding below it and painted the same white making the molding appear even larger. The builder did that as a standard on those 3 rooms.
The chair rail was only in the dining room, and we continued it to the living, foyer and upstairs hallway and did the wainscoting trim and painting below ourselves
in case you noticed the shades different in the foyer, thats because I tested with a color that I am now going with the whole wall as soon as I get a chance to start on that project lol
Old 09-17-2013, 02:40 PM   #8
Rewards Points: 81
I would listen to the other guy and start calling them muntins even though everyone will know what you mean when you call them "glass doors with mullions". Those are muntins. That is all.
one cut is offline   Reply With Quote
The Following User Says Thank You to one cut For This Useful Post:
DIY-Her (10-09-2013)
Old 10-09-2013, 08:25 AM   #9
DIY-Her's Avatar
Rewards Points: 217
lol thanks I tried to edit my subject but it doesn't seem to let me which is strange, because I run a photography website on VBulletin and we can edit our subject or previous messages posted.
I must have seen mullion listed someplace else which was why I started calling them that. After searching muntins, I came up with more hits
Old 10-10-2013, 10:26 PM   #10
You may want to consider glass shelves as well. It might be less obvious that the shelves don't line up with the mullions.
www.thecabinetshopmi.com
DIY-Her likes this.
TheCabinetShop is offline   Reply With Quote
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 06:36 PM
Replacing Doors in masonry wall mwpiper Project Showcase 17 05-12-2011 08:00 AM
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 13 12-08-2009 10:32 AM
Interior door swelling? jdeters79 Remodeling 9 08-15-2009 11:51 AM
