Moving Load Bearing Wall In Basement - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-02-2009, 11:28 PM   #1
Moving Load Bearing wall in Basement
Hi,
I have a 3 floor house. I want to move a load bearing wall around 6 - 8 ft, that is currently approx. in the centre of my basement. For structural integrity, I would leave one column where my existing LB wall is.
I would appreciate if some could advise if it is feasible.
Thank you
iqkhn is offline   Reply With Quote
Old 04-03-2009, 12:44 AM   #2
Registered User
Rewards Points: 5,216
Anyone can answer this but not everyone will. You really need to hire a structural engineer or a contractor. (Who will pay an engineer). The liability involved is family members. Be safe, GBAR ( A column is a vertical support)
Old 04-03-2009, 07:09 AM   #3
There are normally beams with intermediate supporting posts in basements, not usually supporting walls. But what GBAR said, have someone that knows and can see firsthand, have a looksee.
Old 04-04-2009, 06:52 PM   #4
Drywall contractor
Rewards Points: 1,070
If your floor joists for the floor above terminate (from opposite directions) on top of this wall, ABSOLUTELY DO NOT REMOVE THE WALL!. If there's a bond timber with the joists notched or held by joist hangers, you may be able to remove the wall, but extra columns will likely be necessary. A picture would help, but GET A PROFESSIONAL OPINION as outlined above!!
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-05-2009, 05:53 PM   #5
Rewards Points: 5,336
How do you know this is a bearing wall? It would help if you provided photos of the area in question.
I live on Long Island ,NY. There are no bearing walls in any of the houses I've worked in. The weight is carried by a center beam supported by metal posts that span the basement.
Ron
Load bearing floating wall?? ordoro Remodeling 6 04-20-2009 08:09 AM
How to determine if it's a load bearing wall? tripower Building & Construction 8 12-30-2008 10:42 PM
load bearing wall or not ?? akipp General DIY Discussions 4 04-30-2008 09:11 PM
Moving a bearing wall towers22 Building & Construction 2 04-04-2007 11:04 AM
moving another load bearing nailfun Carpentry 2 02-20-2007 09:10 AM
