-   -   Moving Load Bearing wall in Basement (http://www.diychatroom.com/f15/moving-load-bearing-wall-basement-41697/)
iqkhn 04-02-2009 10:28 PM
Hi,
I have a 3 floor house. I want to move a load bearing wall around 6 - 8 ft, that is currently approx. in the centre of my basement. For structural integrity, I would leave one column where my existing LB wall is.
I would appreciate if some could advise if it is feasible.
Thank you
Gary in WA 04-02-2009 11:44 PM
Anyone can answer this but not everyone will. You really need to hire a structural engineer or a contractor. (Who will pay an engineer). The liability involved is family members. Be safe, GBAR ( A column is a vertical support)
Just Bill 04-03-2009 06:09 AM
There are normally beams with intermediate supporting posts in basements, not usually supporting walls. But what GBAR said, have someone that knows and can see firsthand, have a looksee.
bjbatlanta 04-04-2009 05:52 PM
If your floor joists for the floor above terminate (from opposite directions) on top of this wall, ABSOLUTELY DO NOT REMOVE THE WALL!. If there's a bond timber with the joists notched or held by joist hangers, you may be able to remove the wall, but extra columns will likely be necessary. A picture would help, but GET A PROFESSIONAL OPINION as outlined above!!
Ron6519 04-05-2009 04:53 PM
How do you know this is a bearing wall? It would help if you provided photos of the area in question.
I live on Long Island ,NY. There are no bearing walls in any of the houses I've worked in. The weight is carried by a center beam supported by metal posts that span the basement.
Ron
