Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 08-01-2007, 01:49 PM   #1
Moving a bathroom mirror
Recently I've renovated my bathroom with a new sink & cabinet. However, the new cabinet is taller than the one I have had in the past so I am forced to move the mirror higher. The problem with this is that I can't find studs in the wall to insert the mirror holders now, does anyone know of a practical way around this ?
iOsiris is offline   Reply With Quote
Old 08-01-2007, 03:25 PM   #2
You don't need studs. You can use a toggle bolt to do the same job. You can also use a channel on the bottom to rest the mirror in and use the holders on the top.
Ron
Old 08-04-2007, 11:12 PM   #3
alright thanks!
Old 08-28-2007, 01:20 PM   #4
Newb
CrabBucket's Avatar
if you dont want to see the clips at the top you can use Mirror mastic. It comes in a can and in tubes for a caulking gun. The U or L channel at the bottom of the glass and mastic will hold the mirror. You can install the mastic in raquet ball sized blobs and then press the mirror into it.
CrabBucket is offline   Reply With Quote
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Hanging a Heavy Mirror frapha1 General Discussion 6 01-03-2010 12:21 PM
Running into difficulties installing bathroom mirror (pics of the nightmare incl.!) joeyboy General Discussion 18 08-10-2007 11:04 AM
Outlet in bathroom for lights.... TerryL Electrical 5 10-28-2006 09:46 PM
