-   -   Moving a bathroom mirror (http://www.diychatroom.com/f15/moving-bathroom-mirror-10343/)
iOsiris 08-01-2007 01:49 PM
Recently I've renovated my bathroom with a new sink & cabinet. However, the new cabinet is taller than the one I have had in the past so I am forced to move the mirror higher. The problem with this is that I can't find studs in the wall to insert the mirror holders now, does anyone know of a practical way around this ?
Ron6519 08-01-2007 03:25 PM
You don't need studs. You can use a toggle bolt to do the same job. You can also use a channel on the bottom to rest the mirror in and use the holders on the top.
Ron
iOsiris 08-04-2007 11:12 PM
alright thanks!
CrabBucket 08-28-2007 01:20 PM
mirror
if you dont want to see the clips at the top you can use Mirror mastic. It comes in a can and in tubes for a caulking gun. The U or L channel at the bottom of the glass and mastic will hold the mirror. You can install the mastic in raquet ball sized blobs and then press the mirror into it.
