Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-14-2013, 03:26 PM   #1
moulding for toe kick- cabinets
I'm in process of completing kitchen makeover... We ended up installing laminate floor from Armstrong. For the most part- it's holding up well and looks nice- With regard to now installing baseboard trim all around- I have some questions/concerns.. Since with laminate floor - I had to leave a gap where floor butts up to cabinets- the toe kick molding that came with cabinets is not thick enough to cover the gap from where the floor butts up- Any suggestions for this? can I build it out a little from the cabinets- or is there something else that will look nice? The gap is only 1/4" (maybe a little more in some spots)
Huskyfan68 is offline   Reply With Quote
Old 01-14-2013, 06:07 PM   #2
Super Moderator
Add a thin strip of wood to the cabinets so the toe kick is pushed out 3/8" or so---no need for 1/4 round that way---
Old 01-14-2013, 07:11 PM   #3
funfool's Avatar
I would prefer not to build out the front of cabinet before toe kick, although it may be the perfect solution in your case.
If you have a end cabinet that floor buts up to, building out the cabinet on end will not work.
I would be curious what baseboard you are using on the walls, might look tacky if you carry around the cabinets. If stain grade trim, might look pretty good.
If you trimmed the flooring close enough, You might get away with a piece of matching scribe moulding. Or just use 1/4 round.
If it was easy, we would not call it work!
funfool is offline   Reply With Quote
Cabinets To Go! CapnHawk Kitchen & Bath Remodeling 34 02-12-2013 07:42 PM
Should I add crown moulding to cabinets? NickWa Interior Decorating 5 11-26-2011 08:47 PM
Refinishing old Cabinets ryanb4614 Carpentry 4 08-18-2011 07:24 PM
Crown Moulding on Kitchen Cabinets Pie Carpentry 6 11-03-2009 11:21 AM
Need opinions on toe kick under cabinets kestut Remodeling 4 12-05-2006 05:02 PM
