Molding Over Molding, Can It Be Done? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-24-2011, 07:52 PM   #1
molding over molding, Can it be done?
I recently put down a floating prego laminate floor. I am now trying to add molding to finish the job. I was hoping to use a mitre box to cut the molding to 45 degrees and attach it to floor walls. This didnt work out as planned cause my floor already has molding. Is there a way to figure out how to cut the molding to cover up the old molding?
jerry1977 is offline   Reply With Quote
Old 07-24-2011, 08:48 PM   #2
DIY staff
Rewards Points: 7,174
A picture will be needed here ---Is there a reason that you don't just remove the old molding?
Anything can be done--however sometimes the effort,expense and skills make the oddball jobs impractical.---Mike----
Old 07-27-2011, 12:48 AM   #3
Removing molding is one of the easiest things to do. If you are careful, you can do it without harming the wall very much.
If you want to put new molding over the old molding, the new molding will have to be significantly bigger than the old molding, and have clearance behind it to accommodate the old molding.
I agree, a picture here would help this make a lot more sense.
kuj0317 is offline   Reply With Quote
Old 07-27-2011, 02:31 PM   #4
Rewards Points: 5,336
If you had a base molding and then installed the flooring, leaving a 1/4" gap, all you need is a shoe molding or a 1/2", 1/4 round to cover the gap and go against the original base molding.
Ron
B. Franklin 1759
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 06:20 PM
Hardwood threshold molding height crawfucious Flooring 4 04-13-2011 08:44 AM
positioning molding joetab24 General DIY Discussions 0 08-11-2010 07:38 AM
Solidly Securing Picture Rail Molding? Lovegasoline Building & Construction 13 11-25-2009 03:13 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
