Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-15-2008, 12:33 AM   #1
Molding over heat register
Hi
I have an old house where when the previous owners remodel the bath they slightly covered the edges of a 10x10 heat register on the floor. They used vinyl molding so the heat register was sort of removable. I now want to replace the vinyl with wood molding, and if I do so there will be no way to remove the register. How important is it that the register is removable? My only other option would be to put a smaller register there, but I'd really like to keep the antique brass one I have.
thanks
pat
patrickosu is offline   Reply With Quote
Old 02-15-2008, 01:00 PM   #2
Custom Cabinet Maker
cut the trim back, make a frame around the register there, then bring trim up to that
skymaster is offline   Reply With Quote
Old 02-15-2008, 04:20 PM   #3
Wish I had a picture....Seems like this would work if the register was on the wall. The register is on the floor and the molding would be on the wall... Or maybe I don't understand your idea?
Here's a crude drawing...x is the wall, M-molding, equal sign the register, and dash the floor. Maybe I could notch the molding, although not sure how that would work...
xx
xx
xx
xxMM
xxMM
xxMM
xxMM
x==========------------
Old 02-15-2008, 04:21 PM   #4
Master General ReEngineer
Bondo's Avatar
Ayuh,....
Or you just just clearance the molding enough to allow removal of the register....
Old 02-16-2008, 12:07 AM   #5
hms
Remodeling contractor
I would notch the molding slightly to allow for the removal of the register. If you clean it up real good first, you probably won't ever want to remove it anyways. If you are going to be doing something that would require removing it, you would proably be spending enough on the project to warrent replacing that one piece of molding anyways. So therefore just put in the molding. (If this is your own home. If it's a customers home, do it right and notch the molding).
hms is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-15-2008 11:12 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
