#1 |
Mold on railing
We used to hang wet clothes (delicates like sweaters) on this railing. I think the black spots are mold. Any ideas on removing the mold without damaging the finish?
#2 |
Mold on railing
Not going to happen.
Going to have to sand it all down kill the mold and restain and seal. |
#3 |
Super Moderator
Mold on railing
That is NOT mold-----
You have a red oak hand rail with failing finish--- Red oak turns gray or black when it gets wet----the natural tannins in the oak cause the color change-- that hand rail has been washed with water more than once----- Cure? strip, sand, restain and varnish/poly-- and do not wash oak with water-----
New members: Adding your location to your profile helps in many ways.--M-- |
| The Following User Says Thank You to oh'mike For This Useful Post: | BigJim (03-07-2013) |
#4 |
Mold on railing
Suggestions on how to strip? I've never stripped anything like this.
#5 |
Super Moderator
Mold on railing
I'd suggest Marine strip or Stripeze---any good chemical stripper will do---
If you can limit the stripping to the top ans sides and leave the bottom alone --your job will be easier---- You will also need mineral spirits and steel wool--- Do not us water to wash off the stripper---this is red oak and it will turn gray if you do that--- then hand sand---and coat with three coats of oil based poly----
| Display Modes | |
| mold and asbestos | pulper | Flooring | 2 | 09-02-2012 11:40 AM |
| How to - prevent basement mold | crazymountain | How To Guides | 31 | 01-20-2012 08:59 PM |
| Mold found - unsure what to do?? | izzyant88 | General Discussion | 12 | 06-17-2011 07:21 AM |
| Concrobium or White Vinegar? | eis61374 | Remodeling | 8 | 11-17-2008 07:56 AM |
| How to fix broken step railing? | robertr4836 | Carpentry | 2 | 04-18-2008 12:19 PM |
