Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-05-2012, 12:31 PM   #1
Mold in between walls!
I just found black mold growing in between the wall from my laundry room to garage. Do I remove the plaster wall or just the moldly area near the floor?
I have an old stand up freezer that just stopped working on me. I removed the freezer and was going to insulate the garage wall facing the outside. I noticed a water stain on the wall facing the laundry room. After removing the pasterboard i noticed the insulation was in the wrong way and there was mold near the bottom of the wall.
Help! Do i bleach the wall, insulate and then drywall?
rhonda.henry is offline   Reply With Quote
Old 02-06-2012, 08:16 PM   #2
It looks like there might be some water streaks coming from above in the photo. Is there more than condensation going on here?
RenoStruct is offline   Reply With Quote
Old 02-11-2012, 08:55 AM   #3
gravity always wins
Take out the affected drywall and replace it. Go one foot past the last visible water stain. Treatment is not very effective on drywall. If it got wet enough to grow mold, it got wet enough to permanently damage the drywall. Treat the wood and seal it. Solve the moisture issue first.
Old 02-11-2012, 09:05 AM   #4
That old tile board is going to be a challange to remove. I would use my ossilating saw with the diamond blade and come from the back side. Poke it through on the left and right side so you will have a referance point on the other side to draw a line for your cut.
A diamond blade or a tile bit in my Roto Zip is the only things I've found that will cut it.
Old 02-11-2012, 09:26 AM   #5
Scottphys's Avatar
Sorry to see you have this problem.
Please be careful when doing this. Mold spores can spread when disturbed and worse, they can be inhaled.
As much as I dislike the EPA, they do have good information on this. Please check this out before going much further. It has advice on safe removal and how to protect yourself during remediation.
Good luck.
http://iaq.supportportal.com/ics/sup...estionID=21163
Scottphys is offline   Reply With Quote
Tags
mold
Mold on roof sheathing!!! DIYMILF Roofing/Siding 10 08-14-2011 10:11 PM
Inside Walls Cable Fishing/Routing tk3000 Building & Construction 9 07-05-2011 09:15 AM
Mold found - unsure what to do?? izzyant88 General Discussion 12 06-17-2011 07:21 AM
Mold in my brand new house ! dumbguy5689 General Discussion 3 09-07-2010 02:26 AM
basement walls chuckofaltrades Painting 1 10-27-2009 10:51 PM
