Moisture Barrier For Framing - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-02-2010, 08:45 AM   #1
Moisture barrier for framing
I am remodeling a bathroom in a house in New Mexico. I have to replace some of the walls including the framing which sit directly on the concrete foundation. I know in a lot of areas of the country it is recommended to use pressure treated lumber and/or a moisture barrier membrane between the stud and the concrete. In the construction in this area, I do not think I have ever seen a barrier placed between the concrete foundation and the framing. It may not be necessary because this is a dry area, but better to be safe.
I would like to know what kind of barrier should I use between the concrete and the stud. I have 5 mil plastic I was going to lay down and then use concrete screws to attach regular studs to the concrete (not going to use pressure treated studs). I did not see any signs of moisture damage on the old studs I took up from the concrete, so I assume using untreated studs with the plastic would be that much better than what was there before. Any other suggestions that may work better?
pennshaq is offline   Reply With Quote
how important is it for moisture barrier to cover sides of floating floor? conradA Flooring 2 04-29-2010 11:13 AM
Moisture Barrier for Partially Below Grade Grouted CMU Wall Fire4Effect Building & Construction 4 07-06-2009 12:51 PM
Moisture Barrier behind cement board code? scoot_gt Building & Construction 8 09-29-2007 09:53 PM
To Moisture Barrier or Not to Moisture Barrier? cordon Flooring 7 05-22-2007 10:48 PM
moisture barrier - help! jediracer Carpentry 12 10-03-2006 07:32 PM
