Modifying The Ceiling - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 08:55 AM   #1
Rewards Points: 101
modifying the ceiling
Im about to start work on rehabbing our formal living area, and am looking for ideas on what I could possibly do to add some pizzazz to the ceiling. Initially I had thought of simply adding crown molding round the edges, but the more I think about it the more I wonder if I could add something to it that would add a bit if style. One idea was to put some wood beams up that would run across in line with the trusses above to which theyd be anchored. Another thought was to put a 6 high soffit up that would run round the ceiling to a depth of about 2 3 feet from the walls a neighbor did a neat thing with such an idea, using upside down crown molding layed along the lower inside edge to conceal rope lighting running round the soffit, giving a really nice lighting effect when switched on. Alternatively I could possibly add some kind of feature to the center of the ceiling - I'm just not quite sure what to do. Anyone got a suggestion?
Also, if I'm essentially adding the framework and drywall for something like the soffit mentioned, can the W trusses bear some of the weight adequately, or should I be looking to ensure that the walls bear the entire weight? The wood and additional drywall shouldn't weigh more than a few hundred pounds, spread below 8 trusses, plus the walls at either end.
Thanks in advance
timbo59 is offline   Reply With Quote
Old 05-31-2011, 09:11 AM   #2
kwikfishron's Avatar
Rewards Points: 218
Have you thought about a coffered ceiling?
http://www.google.com/search?q=coffe...iw=999&bih=618
kwikfishron is online now   Reply With Quote
Old 05-31-2011, 12:34 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Could you post a pic?
Old 05-31-2011, 10:25 PM   #4
Rewards Points: 101
Here's a picture of the kind of ceiling I had in mind, which is similar to what the friend did. Nice looking, and you can see the lighting effect mentioned in my first post. I never got a close enough look at the friend's work to tell if he set the reversed crown molding right along the lower inside edge, or a bit higher, leaving a distinct corner.
I thought about a fully coffered ceiling, but there are some issues with slight sag in the ceiling between the trusses that would make life difficult. I'd have to replace the entire ceiling and deal with all the hassle of the insulation. That's why I was looking for a relativel easy alternative that would allow me to simply add to the existing ceiling.
Old 06-01-2011, 01:22 PM   #5
Stuck in the 70's
That is a nice pic, but I meant one of your ceiling.
What looks great in an old Victorian home might look weird in a Craftsman bungalow.
The size of the room and type of house will make a difference in what looks good and/or appropriate.
Old 06-02-2011, 09:21 AM   #6
waterman1971's Avatar
Rewards Points: 150
Here is mine.
I have the led rope lighting installed above.
[IMG][/IMG]
waterman1971 is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 01:31 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 02:01 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
