Mitred Cut On Countertops Not Level? - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-01-2011, 01:44 PM   #1
Rewards Points: 682
mitred cut on countertops not level?
I've been checking out counter tops sections for sale and I've noticed the mitered cut is never precisely level. Many are extremely bowed. How significant is this? I've head on assembly you can adjust the surface with hammer and wood block as you glue and screw the mitered sections together, will this be sufficient?
darsunt is offline   Reply With Quote
Old 12-01-2011, 02:09 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
NEW countertops I assume?
XXX
Old 12-01-2011, 02:10 PM   #3
Rewards Points: 13,450
If it's that badly bowed then pick another one. Any I've installed are pretty close to being flat, and yes a tapping block will get it close enough.
Make sure to glue the seam where they come together though before it's installed.
Start at the back and work your way to the frount, that way you can just lift or lower the front edge to get the middle with without have to a tap it.
Leveling Kitchen Cabinets for Granite - how level?? vsheetz Kitchen & Bath Remodeling 13 03-02-2012 07:54 PM
Tub Flange and level tiling DIY Girl Kitchen & Bath Remodeling 2 09-14-2011 07:58 AM
How 'level' is level? BOUTYM Flooring 2 09-04-2011 05:30 PM
level question countrystyle Tools 14 05-01-2011 11:35 AM
How do you determine if a tub is level avtck Kitchen & Bath Remodeling 2 04-12-2011 06:33 PM
