Missing Stair Rail - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-03-2010, 02:18 PM   #1
Rewards Points: 640
Angry
Missing stair rail
The house I bought hast an L shaped stair case... the bottom leg has a rail (go figure) and the top hall ledge has a rail.... but the highest rise part of the L has no rail! but there is a closet there... which fits into the L cavity the closet is only 8 ft high so at one point you could littearly fall off the steps and down to the 1st floor's floor... and the previous owners had little kids bedrooms up there i'm not sure how to fix this because the end of the top hall rail stops right where the rail should go down, but where it goes down if you put a rail there, you'd have maybe half an inch of clearance between it and the closet where the closet is... and there is no newel at the landing of the L shap.... any suggestions on how to fix this? here is a drawing of the situation..... the green areas are where the railing exists, the red lines are things on the 1st floor shown by reference... where I have circled there is no railing at all...
BlueBSH is offline   Reply With Quote
Old 02-03-2010, 04:35 PM   #2
Rewards Points: 5,336
Is the circled area a wall or an open space to the first floor?
The railing should be contiuous from the first floor to the top of the stairs.
If you can, run the railing up the left side of the staircase(going up orientation), up both stair sections.
Ron
Old 02-03-2010, 04:40 PM   #3
Rewards Points: 640
Ron
The circled area on the first floor is a wall, on the second floor is empty space which you could fall right over if there is no railing (which there isnt)... the first floor that area is a closet, I do not have a continious rail from 1st to 2nd floor... they ran the first 3 risers rail up to the front wall of the closet and terminated it there then used the wall of the closet as the "rail" until the landing then turning and going up to the second floor the closet back side is the wall that they used as the railing up to the second floor... but the problem is the closet is only 8ft high... and the 2nd floor is 10ft up... so half the way up the second part of steps you are now higher then the closet and could easily trip and fall over onto the top of the closet or even over the side of the closet it you are on the top 4 steps... my problem is the rail to run from the top newel to the landing it would be pretty much against the wall of the closet... not sure what to do about this issue
Old 02-03-2010, 05:54 PM   #4
The hand rail should be continuous. But if you can not do that you are going to need to build a pony wall on the top of the 8 foot closet wall or put a hand rail up with some pickets. Not sure what will work best for you. A few pictures of the area would help so we can visualize exactly what things look like.
warnerww is offline   Reply With Quote
Old 02-03-2010, 06:41 PM   #5
If there's no wall, you just build a hand rail system of a rail and balusters spanning the open area.
Ron
Tags
railing , stairs
Oak hand rail on existing iron stair railing dougworm Carpentry 8 05-03-2011 06:54 PM
stair hand rail handyman11 Carpentry 9 01-12-2010 10:24 AM
Cutting curved stair rail fittings beerdog Carpentry 2 05-11-2009 07:21 AM
repairing stair with missing riser? darsunt Building & Construction 3 06-18-2008 11:51 AM
Stair rail question shimmy25 Carpentry 8 12-28-2007 11:02 PM
