Min Sheathing - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-24-2010, 01:02 PM   #1
min sheathing
what is the min to be used on a new roof for sheathing. adding on covered deck. contractor had 1/8 sheathing. shouldn't it thicker?
zen120 is offline   Reply With Quote
Old 11-24-2010, 01:45 PM   #2
jlhaslip's Avatar
Rewards Points: 1,464
depends on the roof system, but around here, in snow country, I'd use 1/2" plywood although 7/16" OSB is rated for use.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 11-24-2010, 04:32 PM   #3
Registered User
Rewards Points: 5,466
See below
Old 11-24-2010, 04:35 PM   #4
Registered User
http://publicecodes.citation.com/ico...9_8_sec003.htm
Gary
Mold on roof sheathing!!! DIYMILF Roofing/Siding 10 08-14-2011 09:11 PM
Replacing Rotting Sheathing Behind Chimney. fredhead Building & Construction 4 11-19-2010 08:57 AM
Thinstone on sheathing 3/4" off of the foundation Kasper Building & Construction 3 08-27-2010 08:57 AM
New roof and Sheathing - Install new fascia before or after? hartkem Roofing/Siding 2 06-01-2009 12:12 PM
Moisture on Inside of Sheathing elburritoloco Building & Construction 18 01-19-2009 08:16 PM
