Metal Stud Framing ? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-05-2010, 03:10 PM   #1
Metal Stud framing ?
Hi, I'm pretty new to this site. I just framed out a new shower area of my house with metal studs. I was reading on the subject before I started and it was even easier than people said it would be. I also read that many people attach 2x4's to the inside of the metal stud for nailing in the door frame. The problem I have is this: the 2x4 is 1/4" wider than the metal stud. My question is: should I rip the 2x4 or go with a smaller size piece of wood? Or is the 2x4 even necessary at all? This is a temporary wall for privacy going into the adjoining bedroom.
ct73 is offline   Reply With Quote
Old 02-05-2010, 04:03 PM   #2
Old School
Willie T's Avatar
You use a long section of track there instead of a metal stud. Or just wood studs... without any metal around the door openings.
Willie T
Old 02-06-2010, 12:02 PM   #3
Drywall contractor
Rewards Points: 1,070
Yep, just slip a wood stud into the track and screw it top and bottom. For added srtenght you can back the wood stud with a metal stud and screw them together (flat side of the metal stud screwed to the 2"x4")....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 02-06-2010, 12:15 PM   #4
always frame my openings 6" wider and 1-1/2taller with metal studs on sides and track on top for cripples. Then fill back with one 2x4 on top and 2 on each side for jacks,makes hanging doors.trim easier
The older I get the better I was
Framing out a basment - PT 2x4s with metal studs? wesley8808 Building & Construction 10 01-09-2010 10:39 AM
Basement Sofits - 2x2 or Metal framing whirly Building & Construction 41 01-29-2009 11:14 AM
Metal Stud Framing in Basement toolman327 Building & Construction 2 01-01-2009 07:52 PM
Metal framing for basement Drop Cieling? joliet_man@yahoo.com Carpentry 3 10-22-2008 02:16 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
