Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-20-2009, 08:17 PM   #16
METAL molding!?!?!!?!???
routing the wood trim out should work and some caulk should hide some minor imperfections. Good luck and post pics when done. Just be carefull when grinding cause if you heat the metal up to much it will discolor bad and warp.
ponch37300 is offline   Reply With Quote
Old 01-20-2009, 11:28 PM   #17
Metal door frames are almost always made in two parts. Slide one side in then the other slips behind and is fastened by various methods. Some that you can't get to once it's installed.
Did you open the door and look up? The frames may be fastened in such a way that you can simply remove the trim by unscrewing a retainer or snapping the trim back out of the frame channel.
Rivethead is offline   Reply With Quote
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-15-2008 11:12 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 03:11 AM
