Membrane Between Exterior Wall Plate And Floor - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-10-2013, 09:02 PM   #1
Membrane between exterior wall plate and floor
I just gutted a room and I noticed a fibrous membrane between the exterior wall (insulated)'s plate and the floor. It is under the wall plate and is stapled onto the wall's studs about 1 foot up. The floor is OSB wood and the wall is 2x6 wood as well.
What is this membrane called and what is its purpose?
pvarga is offline   Reply With Quote
Old 12-10-2013, 09:32 PM   #2
Rewards Points: 13,704
Got a picture?
Old 12-10-2013, 10:18 PM   #3
Here is a pic
Old 12-10-2013, 10:20 PM   #4
No picture comes up.
Old 12-10-2013, 10:37 PM   #5
Old 12-10-2013, 10:58 PM   #6
Registered User
Rewards Points: 5,514
Typar house wrap- belongs on the exterior....
Gary
Picture of the outside would help....
The Following User Says Thank You to Gary in WA For This Useful Post:
pvarga (12-10-2013)
Old 12-10-2013, 11:03 PM   #7
Outside is just brick
OK looks like TYPAR house wrap. So judging from that product's description, there is no point to have this on the inside. Why wouldn't the builder have cut it at the floor level?
Old 12-10-2013, 11:52 PM   #8
Maybe just to keep wood chunks and sawdust from bored holes for electrical/plumbing within the walls during construction to avoid having to clean up?
Seems like I can remove this.
Old 12-11-2013, 06:05 AM   #9
There is no need to remove it, just add vapor barrier and sheetrock over it to save time.
It's always best to include your location to your profile.
Old 12-11-2013, 06:55 AM   #10
I'm in Toronto, Ontario, Canada.
I was also thinking the builder might have used it to protect the insulation during construction.
I want to remove it and it would take 1 minute with a utility knife So just wanted to make sure there's no harm in doing so.
Old 12-11-2013, 07:09 AM   #11
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,606
You can cut it out.
I suspect is it wrapped under the sill plate which is an interesting application to say the least.
Old 12-11-2013, 06:22 PM   #12
Registered User
It is your WRB to stop wind/water from wetting the sheathing, to drain down past the floor sheeting/rim joist. Now, any moisture will be directed to your floor sheathing under the wall.... bad, IF the other end of that piece is connected to the wall with vertical application. If just a scrap piece- cut it off though there should have been a continuous bead of caulking along the plate/floor sheathing joint against air infiltration (which you can add now).
Along with solar-driven moisture; http://www.buildingscience.com/docum...n-brick-veneer
You will have less relative humidity on the inside sheathing face with a low perm housewrap (Typar) than a high perm one (Tyvek)- a good thing. Especially if the wall sheathing is OSB, pull some insulation to check. Was there a poly on the studs next to the drywall?
Gary
PS. Yep, I see the poly that should have been caulked to the floor....maybe they ran out of poly, lol. That still doesn't explain why it was wrongly run under the wall.
How to replace a rotten sill plate, floor, and rim joists? Juyaya Building & Construction 14 02-21-2013 08:55 PM
Replacing Rotted Top Plate in Bottom Floor Garage JBGriffith General DIY Discussions 14 04-27-2012 01:49 PM
JAcking up floor to replace bottom wall plate. tpicklesimer Flooring 0 05-24-2011 07:08 AM
Getting Steel Plate Flush with Concrete Floor MrBill_DIY Flooring 7 11-29-2009 08:54 AM
Basement 2x2 furring strips, basement clutter, top plate not attached to floor joists touchsuhas Remodeling 5 12-26-2007 06:01 PM
