Master Bath Remodeling Ideas - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-14-2009, 03:11 PM   #1
Please see my attached file which is a drawing of our master bedroom. We have an open plan in which the master bathroom is right inside of the bedroom without a door and only a 3/4 wall separating it from the bedroom. I'm not sure how we can add a wall with a door because we have a long window that would be in the way of us putting a wall with a door straight across from the end of the 6.5' 3/4 height wall. Ideas?
TracyJ68 is offline   Reply With Quote
Old 02-14-2009, 06:14 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
Not sure if I can properly explain my suggestion. You can extend the half wall to the ceiling to close that off. Next to the sink, you can extend a wall toward the window. IF the window has room above it, you could frame a 2-sided opening at the end of the new wall and just leave it open (no door). While not totally private, it's way better then it is currently.
Here are 2 pics to try to explain myself
Angus
My Albums
angus242 is offline   Reply With Quote
Old 02-14-2009, 06:43 PM   #3
Registered User
Termite's Avatar
That seems like one heck of a solution, albeit not 100% private.
Old 02-14-2009, 08:36 PM   #4
Man of many hats
wrangler's Avatar
Rewards Points: 354
I think Angus has a good plan for what details are given, but it would help if more detailed (dimensions and distances) were given. For example, at first glance, another option might be to continue the wall (full height) along the vanity, add a door there, with a sitting/changing area to the left of the window?
Man of many hats
wrangler is offline   Reply With Quote
Old 02-14-2009, 08:59 PM   #5
(the original)
Rewards Points: 756
Excellent solution, angus. And there's no reason I can see why they couldn't hang a bi-fold in the new opening for a little more privacy.
ratherbefishin' is offline   Reply With Quote
Old 02-14-2009, 09:24 PM   #6
angus242's Avatar
Working off the other ideas shared, you could do something like this too. I just didn't want to take too much out of the actual bedroom. Of course you totally lose the window to the bathroom.
Angus
My Albums
Old 02-14-2009, 10:48 PM   #7
Man of many hats
wrangler's Avatar
Rewards Points: 354
And this as well plays off of Angus' idea:
Man of many hats
Old 02-15-2009, 03:07 AM   #8
Rewards Points: 1,016
what software is being used to create these drawings?
thx
vince
Old 02-15-2009, 07:13 AM   #9
angus242's Avatar
thx
vince
Sketchup
http://sketchup.google.com/
Angus
My Albums
Remodeling a half bath with plaster walls rh8868 Kitchen & Bath Remodeling 26 01-28-2010 12:14 AM
Just Took up my master bath Floor Help!! jamcou2020 Flooring 7 12-31-2008 05:58 PM
NEED HELP WITH IDEAS for remodeling a entire home 2100sq ft 2 stories *Many pictures* BleachCola Remodeling 26 08-23-2008 06:15 PM
Advice on Converting Master Closet to 3/4 Bath Thirdeye Remodeling 9 02-13-2007 07:37 PM
