Masonry Stone Archway - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-30-2008, 09:24 PM   #1
While this isnt a DIY as I'm getting a contractor to handle this - I need some professional advise!
I've got an archway leading from my living room to kitchen and would like to 'stone' it.
I've had 2 companies/contractors out to quote the job and while the prices were fairly similar, the stone they wanted to use was different.
One said I would need a fake stone, and the other said I could use a real stone (that would match the fireplace in our living room)
So, you can see my delima - can real stone be used for a job like this?
The link below is a pic of my archway:
jp33.com/arch/
All comments much appreciated!
-Jeremy
jp33 is offline   Reply With Quote
Old 01-31-2008, 07:55 AM   #2
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
No photo showing By fake stone do you mean foam or cement? Without a photo its hard to say but I would try to match the fire place if it were my house, you don't think the real stone contractor can do it right?
Kingfisher is offline   Reply With Quote
Old 01-31-2008, 08:03 AM   #3
the fake stone would be cement.
it's not that i dont think the real stone contractor can do it, it's just that one said one thing and the other said the opposite. so i thought i would do a little research on my own and try to figure out the best option.
you can paste the link above in your browser (the board wouldnt let me hyperlink) - let me see if i can insert the image
Old 01-31-2008, 08:23 AM   #4
Rewards Points: 5,336
Real stone would require a fairly substantial base to support the installation. This support would need to go all the way to the basement. You don't mention the size of the stone, so the support needed will vary with weight. Good veneer stone is quite a bit lighter and looks just like real stone.
Ron
Old 01-31-2008, 08:31 AM   #5
thanks Ron.
the stone on our fireplace is a granbury cream, chopped. it looks pretty dang heavy to me. i questioned whether mortar alone would hold it in place - sounds like it wouldnt.
is it possible to cut the stone in half? it would cut the weight down, take up less space and might not require a base?
Old 01-31-2008, 08:33 AM   #6
you can see our fireplace/stone in the background of this image
Old 01-31-2008, 09:08 AM   #7
If it was a tighter arch, I'd go with natural stone. The stone might come split already. To have your mason do it, it would be costly. I tend to think the phony stone is your best option. The problem being it might not blend in well with your fireplace. You may want to look at different options such as thin natural stone or (gasp) wood.
tkle is offline   Reply With Quote
Old 01-31-2008, 09:36 AM   #8
i know the supplier of the stone on the fireplace, so i am going to call them today and see what they recommend.
ideally i'm needing a thin stone it sounds like.
how time consuming/costly would it be to have my mason cut the stone himself (just in case thin stone isnt an option)
Old 01-31-2008, 06:23 PM   #9
To many variables to say, but I would guess it would double your labor cost.
using faux stone on interior walls...? DIY4EVER Building & Construction 21 12-21-2007 09:43 AM
Door frame against stone wall elliowb Carpentry 8 12-14-2007 04:03 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 03:56 PM
HELP! Question about Eldorado Stone EricW Building & Construction 8 10-24-2006 04:24 PM
