Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-26-2010, 02:19 PM   #1
masonry concrete work, creating walkout basement?
Messing with the idea of possibly having some excavation done in my yard and creating a walkout/up basement entrance, nothing super fancy, just a door and a stairwell, right now my basement (on the side where i'd be doing this ) is half in/half out, (picture below) i'd be putting the door either in another area that the basement is at half-grade, or in that double hung window frame right there, so basically, what i know would be involved in this project would be:
-an engineer letting me know what additional support i would need,
-a mason, cutting through the concrete wall (3-4ft) wall of the foundation
-excavation on the outside,
-engineer speccing/building out retaining walls to hold the 3-4 ft of dirt, and handling a drainage problem (wouldnt want it to fill up with water and flood the basement.
the area in question:
http://www.demiseguild.org/images/house/P1010272.JPG
an example of what i'd like, although not this nice, the retaining wall, and step work does not ahve to be top notch, this example is courtesy of absoluteremodeling.com
http://www.absoluteremodeling.com/im...ley002.666.JPG http://www.absoluteremodeling.com/im...ey012.666b.JPG
What i want to know is, how big of a project is this? How many people need to be involved? What would something liket his go for, start to finish if i decided to not be involved at all?
geminisr is offline   Reply With Quote
Old 07-26-2010, 03:38 PM   #2
You would call a few contractors and get estimates based on locality.
Cutting out a half wall and digging the opening could be done much more easily then a full wall. The tricky part would be the drain and it's routing away from the house.
Ron
Old 07-26-2010, 04:49 PM   #3
Ron,
Thanks for replying to my post, (and my other one). i'll follow up with this route.
Laminated flooring over basement concrete Woodcutter Flooring 2 10-25-2011 09:55 AM
Insulating Foam *under* concrete basement floor? nilsca Building & Construction 2 03-20-2009 07:58 PM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 02:38 PM
roofing tar on basement concrete floor? bluebee1314 Flooring 3 11-05-2007 07:19 PM
Leaking Basement - Concrete jeepwillies Building & Construction 2 03-06-2007 08:42 AM
