Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-11-2012, 02:40 AM   #16
mark studs discreetly
Originally Posted by hammerlane View Post
1. Put a tape measure in photo for scale.
2.Take a photo of stud locations before drywall goes back up.
3. Open safe deposit box at bank.
4. Put photo in safe deposit box for safekeeping just in case a picture or mirror needs to be hung.
This is not rocket science.
The drywall is already up. Halfway through taping and mudding already. A safe deposit box might be necessary
Originally Posted by kwikfishron View Post
Nail your baseboards to the studs and there ya go. Even after filling nail holes chances are that a keen eye can still find the nails.
That's a good idea too. Thanks!
anuvanoob is offline   Reply With Quote
Old 09-12-2012, 05:12 AM   #17
I worked on a friend's house once where the studs were totally not centered. I put a strip of painters tape on the ground and on the ceiling, marked off where the studs were on the tape, finished dry-walling, taping, painting the walls, then transferred the marks from the tape to the finished walls with a faint pencil mark.
Made life so much easier when we came back to hang cabinets and the tv stand.
weekendwarrior9 is offline   Reply With Quote
Old 09-12-2012, 04:28 PM   #18
Just make a small dot at the top of the wall with sharpie marker, right where each stud is. Thats what we did, if you just make a small dot right where the wall and ceiling meet, it wont be noticed unless you are looking for it
firsttimeremode is offline   Reply With Quote
Old 09-13-2012, 12:17 PM   #19
Those are great ideas too. Thanks!
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 08:31 AM
Making wall studs plumb and on plane laxgrandma Carpentry 1 07-06-2011 06:32 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 05:16 PM
