Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-10-2012, 01:32 AM   #1
mark studs discreetly
I'm currently helping mud and tape my attic apartment that has wonky framing throughout (almost none of them are exactly 16 on center). Since it will be difficult to find studs when hanging/mounting pictures, art, big mirrors, TVs, etc. is there a way I can mark them discretely so I can find them easily after the finishes are installed?
This will be a furnished income property and I'd like the option to move art, mirrors, TVs around periodically, that's why I'm looking for a way to mark studs discretely.
anuvanoob is offline   Reply With Quote
Old 09-10-2012, 02:01 AM   #2
stud finder?
https://www.google.ca/search?q=stud%...uEHentiQKaqYF4
mae-ling is offline   Reply With Quote
Old 09-10-2012, 02:09 AM   #3
Oh, I forgot to mention - I won't use a stud finder. I've had little success with those
Old 09-10-2012, 06:05 AM   #4
how about drawing a simple picture of studs on a piece of paper and mark the distances from one side?
Otherwise, with spacing being uneven, you would have to mark each individual studs which would not be so discreet.
As mae-ling said, I would personally go with an stud finder. Even the inexpensive unit is good at finding studs. Just make sure you install fresh batteries and go slow when scanning.
allthumbsdiy is offline   Reply With Quote
Old 09-10-2012, 06:27 AM   #5
Really?? Invisible ink??
hammerlane is offline   Reply With Quote
Old 09-10-2012, 07:15 AM   #6
Make a good as-built drawing.
Or use a magnet. A rare earth magnet will find the screw heads with no problem. No batteries needed. It will be able to differentiate between the 2 screw heads at a drywall butt joint as well.
7echo is offline   Reply With Quote
Old 09-10-2012, 07:29 AM   #7
AHH, SPANS!!!
a dimensional layout type drawing for each wall along with a pic on a camera works great for locating what ins in the wall later. I've always done that especially for blocking in walls for grab bars to be installed in bathrooms and handicap access areas. The butt end of a hammer works good at finding studs also, just tap on the wall and listen for the solid thunk of a stud.
hand drive is offline   Reply With Quote
Old 09-10-2012, 08:56 AM   #8
Another old fashioned way of dealing with hanging pictures with 0 damage to the walls is with picture moulding.
http://www.bing.com/images/search?q=...8CFE&first=285
Then the art work is hung from wires or HD mono fishing line.
Old 09-10-2012, 10:22 AM   #9
Mark the location of each stud on the floor or ceiling with a piece of tape. I use painter's tape because it's easy to pull up when you don't need it any more
Old 09-10-2012, 10:28 AM   #10
mark each location with cat urine and use a blacklight to find them in the future.
j/k of course
i'd draw a diagram with the stud locations..
fourx is offline   Reply With Quote
Old 09-10-2012, 12:56 PM   #11
LOL! Oddly enough I was looking for a solution on the lines of the invisible ink or cat pee/black light suggestion, but I guess I shouldn't be lazy and go with the as-built drawing suggestions.
Thanks everyone!
Old 09-10-2012, 01:06 PM   #12
That is if they actually hit the stud with the screw or nail lol
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 09-10-2012, 01:17 PM   #13
1. Put a tape measure in photo for scale.
2.Take a photo of stud locations before drywall goes back up.
3. Open safe deposit box at bank.
4. Put photo in safe deposit box for safekeeping just in case a picture or mirror needs to be hung.
This is not rocket science.
Old 09-10-2012, 02:03 PM   #14
Old 09-10-2012, 07:16 PM   #15
Moderator
kwikfishron's Avatar
Nail your baseboards to the studs and there ya go. Even after filling nail holes chances are that a keen eye can still find the nails.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
7echo (09-10-2012)
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 08:31 AM
Making wall studs plumb and on plane laxgrandma Carpentry 1 07-06-2011 06:32 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 05:16 PM
