Marble Tiles Cracking - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-07-2012, 03:04 PM   #1
We have a contractor in our house doing a very expensive remodel of our 2nd floor master bathroom. After getting all the work done except for the finishing touches we started noticing cracks in the 12x12 marble Carrara statuary tiles in straight lines. After removing the broken pieces we confirmed that the cracks were along the seams of the 1/4" hardibacker. Each day we find more tiles with crack lines. The grout and the mosaic insets aren't cracking however. Our contractor is claiming that the floor moves too much and this is a problem with our house. He wants to try to use thinset (sp?) on top of the hardibacker then mortar the tiles. Otherwise he wants to rip up the whole thing and put down porcelain. We are not willing to do that of course as it took us months to decide on a marble tile. Anyone have any advice?
gshukert is offline   Reply With Quote
Old 05-07-2012, 03:14 PM   #2
Rewards Points: 13,960
Any real tile guy would have known this going in and should have built up the floor or floor joist to support it to prevent any movement.
Did he even use seam tape on the joints?
Real stone tiles need 50% less floor deflection then other forms of man made tile.
Old 05-07-2012, 03:17 PM   #3
Civil Engineer
Rewards Points: 4,854
Normally when a professional tile installer undertakes an expensive project such as putting marble down, they perform (or hire out) a stiffness calculation for the underlying floor. The stiffness of the floor is critical in a natural stone installation, as an inadequately stiff floor can lead to cracking of the tile. Possibly this is your problem.
In order to calculate the stiffness of the floor, you need to know the size, span, species and grade, and spacing of the joists supporting the floor. The stiffness between the joists is a function of the type of subfloor used, and the method of attachment. There are on line calculators for floor stiffness, John Bridge has one, and the Schluter website has a lot of information on minimum allowable stiffness for various types of tile.
I suggest you have an in depth conversation with your installer regarding the exact method they used to determine the stiffness of your floor BEFORE they put down the marble. It is a bit hard to imagine, but I guess possible, that your contractor did not do the required computations first, but let's give them the benefit of the doubt and see what they came up with. By the way, the Tile Institute recommends a minimum stiffness of L/720 for natural stone I believe, meaning a maximum center of span deflection of 1/720 the length of the joists. For example, a 10 foot joist is 120 inches, so L/720 means a maximum allowable deflection of 1/6 inch at the center under design load. This generally requires large joists.
Old 05-07-2012, 03:27 PM   #4
I don't see any seam tape on the joints and I doubt he did any kind of stiffness testing. At this point the bathroom is "done" except for the cracks. Recommendations now going forward?
Old 05-07-2012, 03:45 PM   #5
Live with the way it is or the whole thing needs to be ripped out to fix it right.
Old 05-07-2012, 03:54 PM   #6
ccarlisle's Avatar
Get a new contractor. Rip up the old floor, and subfloor, back to the joists. Stiffen the joists if necessary. Put down 5/8" T&G plywood, then another 5/8" layer perpendicular to the first layer, glued and screwed. Modified thinset. "Ditra". Unmodified thinset. Tiles.
Good luck. The old contractor messed this up for you.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Tiles cracking, popping, grout falling out. Mojomama Flooring 8 03-19-2009 08:50 AM
How do I place marble flooring when I have self stick tiles right now? Jezka121102 Flooring 1 08-23-2008 11:06 PM
"grease pencil" on marble tiles! zel Flooring 7 04-29-2008 05:22 PM
Cracking Grout Between Shower Tiles average General DIY Discussions 9 05-08-2007 02:20 PM
