Making Counter Top Fit - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-13-2013, 09:55 PM   #1
Rewards Points: 664
Making counter top fit
Obviously my walls are out of square. I have included pictures of my attempts to install this mitered kitchen countertop.
crescere is offline   Reply With Quote
Old 12-13-2013, 09:56 PM   #2
Rewards Points: 664
This gap is about 2"!
Old 12-13-2013, 09:58 PM   #3
Rewards Points: 664
Is there any way to fix this?
Old 12-13-2013, 10:30 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Yes but chances are you will have to have the angle cut remitered, or recut.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-14-2013, 09:17 AM   #5
K&B Designer
Live_Oak's Avatar
Square up the cabinets as best you can. Buy a counter with no attached backsplash so you can more easily scribe to the wall. Or buy laminate sheets and make your own. 2" out of whack is pretty serious though. I'd want to asses why it's that far off.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 12-14-2013, 11:41 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Good thought, that would sure be a way to fix it. They would still need to cut the miter to make the tops swing back against the walls. Even if they built it and butted the HPL, instead of mitering, they would have to cut it out of square to make it fit.
I agree, make the cabinets fit to the walls instead of sitting away from it. You will probably have to install a filler at the 90 degree point to fill in the gap left when you push the cabinets back against the wall.
Jim
Old 12-14-2013, 02:13 PM   #7
Rewards Points: 664
It is hard to tell from the picture, but the cabinets are against the wall. I have no knowledge of how to properly miter the counter top, so I would probably really mess that up and be left with a worthless counter top. I paid a lot for this one, so I do not want to scrap it and get a new one with no back splash.
I was thinking of pulling the drywall and adjusting the studs to make the room square. I would only have to do that for about 6.
Old 12-14-2013, 02:45 PM   #8
Rewards Points: 13,458
And once the wall square where the backsplash is, what do you do with the rest of the wall? There would be a 2" step there.
Old 12-14-2013, 03:24 PM   #9
Rewards Points: 14
Push the left side all the way to the wall and measure the gap at the front of where your corner cut is. Let's say it's 1/2" as an example. Now measure a 1/2" from the edge of the back corner of the left side counter and scribe a line from that mark right to the tip of the front corner. That is what would need to be removed in order for the counter top to fit flush on both walls and the joint to meet flush.
nvrfinished is offline   Reply With Quote
Old 12-14-2013, 05:15 PM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Call around town and see if there is a counter top shop there, they will have a the large saw that can recut the miter, they shouldn't charge much to cut both angles the same.
Jim
granite counter top Startingover Carpentry 9 12-04-2013 09:41 PM
Laminate counter tops, can they be joined? Strife_Design Kitchen & Bath Remodeling 6 07-05-2013 11:12 AM
Making a wood counter screwy Carpentry 4 04-30-2011 05:56 AM
Receptacle in kitchen island raised counter backspash interplexr Electrical 1 05-16-2009 06:06 AM
laminating counter tops ponch37300 Remodeling 3 05-13-2009 10:13 PM
