Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-31-2012, 11:30 PM   #1
Make my own ceiling tiles?
Hi,
I am working on finishing our basement. I want to do the ceiling grid system that is flush mount (headroom is an issue - but we still need to be able to access pipes, etc). It seems to me that ceiling tiles are real expensive. The real nice ones are way up there in price. Has anyone ever made their own? Can you take a 4 x 8 sheet of 6mm prefinished panelling and rip it down to 2x 2 tiles and then just lay those in the grid system?
Has anyone tried this?
Thanks for any advice.
Seansmom is offline   Reply With Quote
Old 10-31-2012, 11:49 PM   #2
yes you can if you want to. you can also buy sheets of drywall and cut them into 2x2 squares and use them also, painted of course. they will deaden the sound too.
Old 10-31-2012, 11:50 PM   #3
May want to run that idea past your building inspector. May not meet local fire codes.
If you do it I'd suggest staining and sealing it while it was still in 4 X 8 sheets.
Old 11-01-2012, 12:01 AM   #4
Thanks! I never even thought of drywal, that would be easy and inexpensive. I will have to check on the drywall weight, I think the grid system I am looking at is limited to 1.25 pounds per square foot.
And the panels I was looking at are standard prefinished wall panelling, if their ok for walls would the fire code be different for ceiling?
Old 11-01-2012, 12:04 AM   #5
With living space above it may be. Only one way to find out.
Old 11-01-2012, 12:30 AM   #6
Many places do not allow wood panelling. Even though you can buy it at the store.
1/2" drywall is about 1.7lbs/SF so it is to heavy.
Their is a lightweight 1/2" that may work.
mae-ling is offline   Reply With Quote
Old 11-01-2012, 12:32 AM   #7
also how much will a 2' by 4' panel sag?
Old 11-01-2012, 11:54 AM   #8
firehawkmph's Avatar
Use the lightweight 1/2" drywall as suggested, cut it into 2' x 2' squares, and buy commercial grid at a drop ceiling supplier and you'll be fine.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
mae-ling (11-01-2012)
Old 11-02-2012, 07:47 AM   #9
Thanks so much for all of the advice. I'll let you know how it turns out?
tin ceiling tiles as a kitchen backsplash golfgirl Kitchen & Bath Remodeling 4 04-25-2012 11:56 AM
Flushmount Ceiling Tiles simon Remodeling 4 07-20-2010 02:26 PM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 01:15 PM
staple-on t&g ceiling tiles Tonglebeak Remodeling 9 02-10-2010 05:07 PM
Dropped ceiling tiles? CooperChloe Building & Construction 10 02-09-2009 09:31 AM
