Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-08-2008, 01:09 PM   #1
LVL lambeam and me...
so, i have a LVL lambeam. its 1 3/4 thick 12" tall and 20 feet long. will this support a an 18' span if supported at each end? it will be supporting a ceiling on one side of it only, with only insulation above the ceiling. thank you for your time....
shame302 is offline   Reply With Quote
Old 05-08-2008, 04:13 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
Call the manufacturer of the beam. They will tell you the longest allowed unsupported span figures. Ask for the engineering department and tell them what you want to accomplish. They'll give you thumbs up on it or not.
angus242 is offline   Reply With Quote
Old 05-08-2008, 10:55 PM   #3
buletbob@optonline.net's Avatar
a single ? no! it will sag over time
buletbob@optonline.net is offline   Reply With Quote
Old 05-09-2008, 10:53 AM   #4
You need either three 16 inch beams or two 18 inch beams.
UFoPilot is offline   Reply With Quote
Old 05-10-2008, 10:44 AM   #5
the man. stated i would need 2 9" LVLs so i went with another 12 to make it a double. the inside span is actually 16'. if i ever need to add a post down the road that would be easy enough. thanks again for your time!
