#1 |
Lowering Ceiling in Great Room
My Great Room is 17 feet wide by 24 feet long with a 18 foot ceiling height on the inner wall and a 10 foot ceiling height on the exterior wall. I am on propane and want to lower the ceiling to a straight 10 feet to cut my heating costs. I was thinking that I would run engineered joists across the width (17' wide) walls by attaching a perimeter joist around the inner walls and using joist hangers to attach the joists. There would be the weight of the 1/2" sheetrock that it would have to be supported My question is whether this sounds like the right way to go about this or do you have a better suggestion.
#2 |
Old School
I think you might be surprised at how little difference lowering the ceiling will make. If high ceilings were such a problem, they would find it almost impossible to heat all those high-ceiling cathedrals, sports arenas, and hotel, hospital and office lobbies. Not to mention theaters.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Willie T |
#3 |
Xtreme DIY'r
My cathedral ceiling in the great room is ~12' high, sunroom is maybe ~11'
Higher ceilings make a room (seem) much bigger 10' is still a nice height...but the room will seem quite a bit smaller For 17' span, ceiling only - with insulation, probably need a 2x10 16" OC depending upon the wood & what you will do with the space above Some people use the closed off area for storage Span Calc: http://www.awc.org/calculators/span/...rcalcstyle.asp |
#4 |
In commercial situations, dropped ceilings are suspended from over-head with 'pencil rod'. Thes rods support horizontal stringers, from which the finished ceiling is suspended.
You should get advice from an architect, as they are familiar with the proper methods required! |
| Display Modes | |
| Dining room renovation + Tray ceiling | hyunelan2 | Project Showcase | 24 | 08-17-2010 10:43 AM |
| Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? | Lovegasoline | Painting | 4 | 11-25-2009 03:06 PM |
| ceiling joist size for 10.6 foot width room | hammeredmythumb | Building & Construction | 4 | 08-28-2009 02:54 PM |
| Builder skipped ceiling joists in bonus room need advice | minicus | Carpentry | 31 | 08-11-2008 11:44 PM |
| Pot lights in a drop ceiling | Howdy | Electrical | 3 | 03-14-2008 09:23 PM |
