Looking For Ideas/pictures On A Wall-mounted Countertop - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-11-2008, 11:25 AM   #1
Looking for ideas/pictures on a wall-mounted countertop
Working on a breezeway (porch room) remodel. We want to put an 8' long, 24" deep countertop against one wall to serve as a bar and eating area. The bar/countertop will most-likely be two layers of particleboard, one layer of 1/4" cement board, and then some kind of tile/stone on top. I'd like to avoid having legs on the front edge of the countertop, but I have yet to find a nice set of support brackets that will support the weight. I do have woodworking tools (table saw, jointer, planer, router, etc), so I could build something if I had an idea.
So far, I found these wall brackets, but this isn't exactly what we're looking for. Wood corbels, large enough to support a 24" deep countertop, are expensive ($50+).
Pictures and suggestions would be appreciated.
Thanks,
Kevin
ktulu05 is offline   Reply With Quote
Old 06-11-2008, 01:07 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
You meant PLYWOOD, right?
Angus
My Albums
angus242 is offline   Reply With Quote
Old 06-11-2008, 01:12 PM   #3
angus242's Avatar
http://www.kitchensource.com/table-bases/ha-5-103.htm
http://www.shortrunpro.com/counterto...w_vhv1ytw.aspx
http://www.fantasysteel.com/brackets.html
http://www.galleriacollection.com/ironworks/
I think trying to support that kind of weight is going to cost more than it sounds like you want to spend. Perhaps legs of some sort on the ends?
Angus
My Albums
Old 06-11-2008, 01:32 PM   #4
Yeah, that's more than I want to spend. I think I'll have to look into fabricating some legs. Any pictures of something like that would also be appreciated.
Old 06-12-2008, 06:46 PM   #5
Rewards Points: 77
1) we went with shrtrunpro near-invisible angles for our 24" deep breakfast bar. their website has some guidance on design too. And, their customer service was excellent.
2) there are a number of premade legs available, but we found them through numerous google searches. ugh! in the end, we used IKEA UTBY SS legs for our "flying" countertops. sturdy and stylish.
1655graff is offline   Reply With Quote
Old 06-13-2008, 04:00 PM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
Will the ends be supported?
Old 06-16-2008, 01:04 PM   #7
No, the ends are not supported. I was going to put up steel angle on the back wall to hold up one side of it, but the other 3 sides would be freestanding.
Old 06-30-2008, 03:50 PM   #8
countertop
This sounds more involved than what you were planning. I hate to throw you for a loop, but what about some kind of freestanding "island" of butcher block table/island design? It would be much less expensive and while it would not be flush against the wall, you could place it next to the wall and get some of the functionality you're looking for.
Allison1888 is offline   Reply With Quote
Old 06-30-2008, 03:58 PM   #9
I found these brackets at Ikea for $5.00 a piece. I think it would be safe to put an 18" deep counter mounted on these brackets. Since they are so cheap, I'll probably use 5 or 6 to balance the load. Given that other metal brackets are $30-$100+ each, these are a steal.
Old 06-30-2008, 07:09 PM   #10
Rewards Points: 77
a few thots...
when we looked at them, I think I recall that they were hollow tubing.
SO I"d make sure IKEA has something in writing that says what materials/loads and flex they are designed to for and that they are suitable for your project.
This is important in your project because the stone/tile top you are looking to support. And some brackets will never be designed nor can be built for your needs.
Old 06-30-2008, 09:45 PM   #11
It looks like these shelves are designed to go along with it, and they say 88 pounds. They call this their "heavy duty" storage collection. I can also bolt some steel angle to the wall to form a ledge for it to sit on along the back, and then these brackets would only support part of the load.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Wall mounted scart / aerial socket miked Electrical 5 01-05-2007 06:40 PM
