Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-17-2010, 02:49 AM   #1
Living room remodel question?
I just bought this mobile home, and as you can see in the pic, it has beams running across the ceiling from one side of the living room to the other, with the marriage wall in the middle. I originally thought I would add crown molding but then I worried that the ceiling might look too "busy" with the molding next to the beams. Then I thought maybe I'd just add quarter round instead. I've also considered painting the beams white, so they would blend, but I'm not crazy about that idea, cuz I kinda like the way they look now.
I'm totally new at this, so there's probably plenty of options I don't even know about. For clarification, I am removing the wall strips, filling the gaps with joint compound, prepping the walls with TSP, Kilz'ing all the walls, and then painting them Antique White and the trim will be Arctic White, and adding a chair rail where the half-wall paneling meets the upper wall. (I'm worried that the dark beams are not going to match the room once I finish painting it in such light colors).
So now that you know what the rest of the room will eventually look like, should I go with crown molding or just quarter round? Or something else that I don't even know about?
Suggestions?
Living room remodel question?-dscn5457.jpg   Living room remodel question?-dscn5460.jpg
peasantgirl is offline   Reply With Quote
Old 10-20-2010, 11:07 AM   #2
Do what you stated and then look at the beams. Maybe live with it a few days, then decide if they're too dark.
Ron
Old 10-20-2010, 12:18 PM   #3
Stuck in the 70's
Blondesense's Avatar
JMHO, but I would NOT do crown molding if you are keeping the beams. Those are two totally different looks and I don't think they would play well together. I would use a trim that is similar to what is currently there, at the most.
Q about circulating warm air from living room.. Alan HVAC 5 12-11-2009 09:26 PM
Adding A Ceiling Fan To Living Room jte1130 Electrical 1 05-28-2008 04:05 PM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 06:34 PM
question about cleaning a boiler room Piratehart General Discussion 1 02-14-2006 01:58 PM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 04:33 PM
