A Little Header/sill/rim Joist Help? - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 06:39 PM   #1
A little header/sill/rim joist help?
OK..My house was built in the 50's..my wife and I have been doing things here and there to fix it up/ improve/ update the place. Yesterday I got into the utility room and replaced the back door..I noticed a little rot below the door..It was late so I hung the door anyway (just because I needed to fill the hole)..Today, I stated to pull up some flooring and found that the boards under the door are pretty rotten and need to be repaired/replaced. These boards are the rim joist or header boards or sill?...Im not sure. Will my house have to be jacked to replace these boards? The floor joists run parallel to the rotten board. There is a porch (4x4 concrete porch like on a moblie home) on the outside that will have to come down because there is no flashing to prevent this water damage...What am I looking at for a fix? The boards seem to be rotten about a foot or two on the left side of the door and seems to be good on the right side of the door(maybe 8 inches to the right).
A little header/sill/rim joist help?-floor-paint.jpg   A little header/sill/rim joist help?-paint-floor.jpg   A little header/sill/rim joist help?-floor-3.jpg
kevin125 is offline   Reply With Quote
Old 10-19-2011, 06:50 PM   #2
Framing Contractor
Rewards Points: 112
I would carefully remove the door and rehang it later. It will make the repair work so much easier. Hard to tell from the pics if that will need to be supported. Not really a big deal to prop it u temporarily.
sixeightten is offline   Reply With Quote
Old 10-19-2011, 06:54 PM   #3
Yeah...I will remove the door for repairs..but its dark and raining outside right now
After looking further into it..there is another beam that runs the length of the house on the other side of the door...maybe 6 feet to the left.
Old 10-19-2011, 06:56 PM   #4
Framing Contractor
Rewards Points: 112
Hopefully the plywood is not rotted. If that joist is only under the door and wall, and not supporting the structure, youcan probably get by without jacking it up.
Old 10-19-2011, 07:00 PM   #5
Thats my biggest question..is if it needs to be jacked...if not, I will do the work myself. Its not much there now, I could pop a hole all the way through with a hammer (easily if i wanted)...real moist wood!
Old 10-28-2011, 05:29 PM   #6
OK..just an update...
I read somewhere that said, if you're not sure a wall is a load bearing wall, assume it is...so I ended up jacking the wall up. The more flooring i pulled back/up, the more problems i found with the joists..I replaced everything with PT wood..even the sub floor. Got every thing as level as i could get it and also put down laminate flooring. All i have left to do is replace the trim and paint!!
Nice 'lil DIY project!!
$200 door ended up costing a lot more, but I am glad I found and fixed the problem!!
Old 11-13-2011, 04:20 AM   #7
There's probably a lot of black mold. You have to get rid of that first.
See
http://www.epa.gov/mold/index.html
kc0gnu is offline   Reply With Quote
Better to cut batts than scrunch them to open up space at rim joist? darlingm Insulation 2 08-30-2011 01:26 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 02:30 PM
