Linoleum Over Old Tile Mortar? - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-10-2007, 04:27 PM   #1
weekend warrior
Rewards Points: 150
linoleum over old tile mortar?
I pulled up an old tile floor in the kitchen. The mortar/tile adhesive underneath is all uneven and such with the ridges. I need to go over it. Some ideas I had were:
-By hand, apply tile cement into all the ridges, and smooth it all out the best I can
-Use self leveling concrete, but I was worried about having to seal every little wall/crack to keep it from running out
-Just go over the whole floor with cement board.
I'm still debating on what to use to finish it off. I was thinking linoleum just because of the hassle of tile. But, I do have enough tile to do it if I can get it all leveled out.
There's a spot or two where it's uneven due to being under an appliance/cabinets when they worked on the floor in the past.
I just want to know the best way to smooth it all out so I can apply flooring.
johnny331 is offline   Reply With Quote
Old 08-10-2007, 10:35 PM   #2
Rewards Points: 5,336
Can the substrate this mortar is on, can it be removed? If not, get off all the inordinate high spots and put down a layer of plywood. If you're going with sheet vinyl, use 1/4" luan ply. Pay close attention to the nailing pattern and instructions about the ply seams the vinyl floor manufacturer has.
Ron
Old 08-13-2007, 10:39 PM   #3
I've laid linoleum before without being careful to get it exactly smooth and flat and been disappointed with the results. Tiling over an uneven floor is a nightmare, too.
So, basically, you'll need to get it level. If it's not perfect, I'd prefer tiling it over linoleum, myself.
StevePM is offline   Reply With Quote
Old 08-13-2007, 11:10 PM   #4
weekend warrior
Rewards Points: 150
The tile/mortar was put ontop of some sort of 1/4" (looks like) luan. It's proving extremely difficult to get off, thousands of nails.... so I really don't want to go that route if I don't have to.
Using self-leveler seemed like a revelation to me... Any reason that wont work? I figure it'd give the sturdiest base resting ontop of the old stuff, for new tile...
Old 08-14-2007, 05:58 PM   #5
You need to decide what floor is going down before you can decide how to proceed.
For a successful tile floor installation you need at least 1" of wood substrate and a cement backer(1/4" or 1/2").
You removed the tile for a reason, what was it.?
Ron
Old 08-15-2007, 04:53 PM   #6
weekend warrior
Rewards Points: 150
removed it for aesthetic reasons, didn't like the look.
I will do new tile, that will probably be the best investment.
So there's at least a 1" substrate there now. So do you suggest I level out the mortar that's there, with more mortar, get it even as I can, then just apply some tile-backer ontop?
Sorry to be so dense, but I'm young so everything's pretty new to me, don't have the 'ol "years of experience"
Old 08-15-2007, 10:42 PM   #7
A pro could make it level as he laid the tile -- you and me need to get it level first
Level first and the all you need to worry about is laying tile.
Old 08-16-2007, 10:57 PM   #8
You need to remove the 1/4" luan. This is not an appropriate tile substrate. Yeah I know, alot of nails. But when you remove the luan, you get a level place to thinset and nail down some 1/4" cementboard.
Ron
Can I ceramic tile over linoleum? havetime_4fun Flooring 20 12-30-2011 06:29 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Porcelain tile over linoleum. STEPHENWANGEL Remodeling 12 08-17-2007 09:46 AM
Tile over old linoleum? SeattleDuck Flooring 1 09-22-2006 02:58 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
