#1 |
limestone coping around pool
the limestone coping around pool looks dirty and old. I have srubbed it with everything recommended now i want to know if it would work to be stained or painted? thanks rachel
#2 |
Have you pressure washed the stone if not I'd try that, use a masonry cleaner while your at it. You could also try muratic acid, brush it on or use rubber gloves and a sponge then rinse after 2-4min. . I'd start with a 60% acid solution and work your way stronger till you get results.
| Display Modes | |
| Inground Pool Leak - suggestions needed | hravenkel | Plumbing | 10 | 03-21-2011 09:39 PM |
| Pool Cement Apron Issue | ajdevoll | Building & Construction | 7 | 09-08-2010 10:57 PM |
| Swimming Pool subpanel | tedpoppke | Electrical | 3 | 08-24-2010 09:59 AM |
| Movement of cement pool deck around inground pool | sgagnier | Landscaping & Lawn Care | 1 | 07-05-2010 01:31 PM |
| Help with cutting Pool coping | sarchevyman | Flooring | 2 | 04-27-2008 06:09 PM |
