-   -   limestone coping around pool (http://www.diychatroom.com/f15/limestone-coping-around-pool-102843/)
haldumas 04-26-2011 09:42 PM
the limestone coping around pool looks dirty and old. I have srubbed it with everything recommended now i want to know if it would work to be stained or painted? thanks rachel
STL B. 04-28-2011 08:30 AM
Have you pressure washed the stone if not I'd try that, use a masonry cleaner while your at it. You could also try muratic acid, brush it on or use rubber gloves and a sponge then rinse after 2-4min. . I'd start with a 60% acid solution and work your way stronger till you get results.
fixrite 05-03-2011 10:34 AM
DO NOT forget the safety goggles...........
