Leveling A Shower Pan - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-03-2009, 03:13 PM   #1
Rewards Points: 14
Leveling a shower pan
I am putting in a new shower pan and the floor is almost an inch out of level in 36 inches.
The floor joists run perpendicular to the level and then there is 1x8s on top of the joists and then I just put down a sheet of 3/4" ply and noticed how out of level it is. What is the best way to fix this problem? Thanks
ponch37300 is offline   Reply With Quote
Old 04-03-2009, 03:39 PM   #2
Remodeling Contractor
run foam strips around the edges and pour in self-leveling cement.
Old 04-03-2009, 03:55 PM   #3
Rewards Points: 14
Can I shim the shower base or could I put down a bed of mortar and push the pan into the mortar till it's level?
Or is there an inexpensive self leveler that will work? The ones I've looked at are pretty expensive? Thanks for your advice.
Old 04-03-2009, 04:36 PM   #4
Quality costs. But yes you can set it into plaster bed. Might not be the best in a mortar bed, check directions. Some materials do not like wet cement. Most likely not a problem.
Old 04-03-2009, 05:54 PM   #5
Rewards Points: 14
Thanks for your help Bob. I ended up putting a bed of mortar under the pan and it came pretty close to level, about 1/8" off. I thought that was pretty good considering it started off over an inch out of level and it's solid now. On to the densshield tommorrow! Thanks again for your help
shower drain leveling all thumbs Plumbing 1 04-01-2009 02:55 PM
Plumbing in the shower head obeans Plumbing 3 03-11-2009 04:08 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 02:02 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
