Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-09-2010, 08:13 PM   #1
Lay concrete over concrete?
I have an old nasty looking concrete patio. I want to refinish it. The plan is I was going to put some 2x4's around it, pour 2 inches of concrete on top, than I have a stamping tool to give it a rock look and I was going to press that in around the patio than let it dry.
Will this work? Other than cleaning the old concrete what prep should I do?
Does it need to be reenforced? I dont see how I would with the stamping tool.
Thanx!
cademan is offline   Reply With Quote
Old 07-09-2010, 08:22 PM   #2
nap
You talking to me?
nap's Avatar
where are you located? Exposed to freeze/thaw cycles?
Old 07-09-2010, 08:29 PM   #3
Northern California. Gets pretty cold in the winter but not freezing. Here is a better breakdown if it will help
http://www.idcide.com/weather/ca/olivehurst.htm
But I don't think it ever quite hits freezing
Old 07-09-2010, 09:23 PM   #4
General Contractor
You would need to purchase or order a mix that specifically states it's ok for a 2" slab. Run of the mill bagged concrete is usually suited to 4", maybe 3" slabs.
Are you sure your stamp needs to press all the way through the concrete? You are not easily going to fit re-bar in a 2" slab, but in a thicker slab the bar would keep cracks from turning into crevasses.
Have fun,
Rory
Portland, OR
Rory Read is offline   Reply With Quote
Old 07-09-2010, 09:34 PM   #5
The press doesn't have to be pushed all the way through, it was just the plan. but two inches doesn't leave a very big press with rebar.
What if I make it thicker? I have to go remeasure the distance between the porch and my door, but I think its only about 4 inches, thats why I estimated 2 for the slab. Its also been suggested to me if I clean the old concrete very well and also lay an epoxy before I lay the concrete, than use a concrete with fiberglass strands?
Any thoughts?
Old 07-09-2010, 10:00 PM   #6
Wire Chewer
Red Squirrel's Avatar
I forget what it's called, but there is a special glue you can add to your cement mix. It looks like milk. That may help make sure it adheres properly. It's used in parging.
Red Squirrel is online now   Reply With Quote
Old 07-10-2010, 01:33 AM   #7
Concrete & Masonry
This is only my opinion, but the prep work I would personally do would involve removing the existing concrete.
A 2" topping is reiant on the stability o fthe existing patio. S, if the existing patio is aciveley moving & cracked, expect the same fron the topping in a short time.
As for the stamping, Good luck. There is a fairly substantial learning curve involed in decorative concrete if you are by any means "picky".
jomama45 is online now   Reply With Quote
Old 07-10-2010, 09:55 AM   #8
Current concrete isn't ruined, its just an ugly grey slab and I am trying to think of a way to nice it up
Old 07-10-2010, 10:15 AM   #9
the Musigician
DangerMouse's Avatar
If it's an ok slab, not broken or all cracked, maybe just putting on a nice epoxy coating would be best/cheapest/easiest?
There are some pretty awesome looking ways to do a real strong, watertight surface!
Looking around http://www.daichcorp.com/ at some of the ways these coatings can look might help?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
